Altair RISE
Nominate Yourself Now!
Bug Report
User: "[Deleted User]"
New Altair Community Member
Updated by Jocelyn
Hi
lately I up date my RM but when I import any excel to it, it can not understand space character.
mbs
1 - 7 of 71
    User: "sgenzer"
    Altair Employee
    hi @mbs thank you for this. I will need more information to file a report: your data set, your process XML, and some screenshots. Keep in mind that a "bug" occurs when you get a window saying that you have encountered a bug and it has a "Report Bug" button. If you get red error bubbles, those are not bugs. Those are normal error messages meaning there is a problem with your process and RapidMiner is trying to help you fix it.
    Scott
    OP
    @sgenzer
    Thank you for your answer but when I up date it I understand this problem and with @varunm1
     try to solve it but still it has problem.
    Thank you
    mbs
    OP
    @sgenzer
    Not only "space" also it can not understand "dot" :/
    Regards
    mbs
    User: "sgenzer"
    Altair Employee
    hello @mbs ok I looked at your data + process and unfortunately you just have a spelling error. Hence the testing set attribute "WRITE.CONTACTS" does not equal "WRITE.CONTATCS".
    Scott
    OP
    Hello
    @sgenzer
    Thank you for your answer. I fix all the problem that you mentioned but still it has problem.
    could you plz tell me what kind of bug is it?
    All the best
    mbs
    User: "sgenzer"
    Altair Employee
    @mbs can you pls send me a new process?
    OP
    sure
