🎉Community Raffle - Win $25
Join and Win
Split cell data into rows
User: "thiago_caixeta"
New Altair Community Member
Updated by Jocelyn
Hello,
Is there a way to split data in a cell to rows, instead columns?
Example:
What I really need now is the results one below the other, instead of columns....
Thank you!
1 - 5 of 51
    Puh,
    i think not with TurboPrep: Are normal processes also fine?
    Cheers,
    Martin
    OP
    Hi mschmitz,
    Yes, is there a way to do it?
    User: "BalazsBaranyRM"
    Accepted Answer
    Hi,
    you first split to columns, then use De-Pivot to transform these to rows.
    Usually it's good to only work on a subset of your attributes (the column you want to split and some kind of Id column to join back later) because de-pivot makes working with all columns harder.
    Regards,
    Balázs
    User: "lionelderkrikor"
    Hi @thiago_caixeta,
    I propose an alternative method using a Python script  (Pandas library) to perform what you want to do :
    To execute this process, you will need :
     - to install Python on your computer.
     - to install the Python Scripting extension from the Marketplace.
    The process :
    <?xml version="1.0" encoding="UTF-8"?><process version="9.4.000-BETA">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.4.000-BETA" expanded="true" name="Process">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="2001"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <process expanded="true">
          <operator activated="true" class="utility:create_exampleset" compatibility="9.4.000-BETA" expanded="true" height="68" name="Create ExampleSet" width="90" x="179" y="85">
            <parameter key="generator_type" value="comma separated text"/>
            <parameter key="number_of_examples" value="100"/>
            <parameter key="use_stepsize" value="false"/>
            <list key="function_descriptions"/>
            <parameter key="add_id_attribute" value="false"/>
            <list key="numeric_series_configuration"/>
            <list key="date_series_configuration"/>
            <list key="date_series_configuration (interval)"/>
            <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
            <parameter key="time_zone" value="SYSTEM"/>
            <parameter key="input_csv_text" value="Att_1&#10;ibmadmin,so&#10;soadmin&#10;autadmin&#10;ssdadmin,iamadmin&#10;psmadmin"/>
            <parameter key="column_separator" value=";"/>
            <parameter key="parse_all_as_nominal" value="false"/>
            <parameter key="decimal_point_character" value="."/>
            <parameter key="trim_attribute_names" value="true"/>
          </operator>
          <operator activated="true" class="generate_id" compatibility="9.4.000-BETA" expanded="true" height="82" name="Generate ID" width="90" x="313" y="85">
            <parameter key="create_nominal_ids" value="false"/>
            <parameter key="offset" value="0"/>
          </operator>
          <operator activated="true" class="python_scripting:execute_python" compatibility="9.3.001" expanded="true" height="103" name="Execute Python" width="90" x="514" y="85">
            <parameter key="script" value="import pandas as pd&#10;import numpy as np&#10;&#10;# rm_main is a mandatory function, &#10;# the number of arguments has to be the number of input ports (can be none)&#10;def rm_main(data):&#10;&#10;   new_data = pd.DataFrame(data.Att_1.str.split(',').tolist(), index=data.id).stack()&#10;   new_data = new_data.reset_index([0, 'id'])&#10;   new_data.columns = ['id','Att_1']&#10;   &#10;    &#10;   return new_data"/>
            <parameter key="notebook_cell_tag_filter" value=""/>
            <parameter key="use_default_python" value="true"/>
            <parameter key="package_manager" value="conda (anaconda)"/>
          </operator>
          <connect from_op="Create ExampleSet" from_port="output" to_op="Generate ID" to_port="example set input"/>
          <connect from_op="Generate ID" from_port="example set output" to_op="Execute Python" to_port="input 1"/>
          <connect from_op="Execute Python" from_port="output 1" to_port="result 1"/>
        </process>
      </operator>
    </process>
    Hope this helps,
    Regards,
    Lionel
    OP
    Worked fine!!!!
    Thank you very much for your help!!
