🎉Community Raffle - Win $25
Join and Win
About temporary files generated by the server
lzuUser: "lzu"
New Altair Community Member
Updated by Jocelyn
Hello,
In the server /tmp/ directory where I installed RMS, I found some temporary files, whether I could delete them, or specify a directory to store them。
My RMS is installed in /usr/local/rapidminer/ , But I'm executing the installation command in the /tmp/ directory,
These files were generated in the /tmp/ directory, affecting me to upload other temporary files。
Will it affect the normal operation of RMS if I delete these files?
And how do I assign it a storage directory?
Best,
LiuWenlong
1 - 4 of 41
    rfuentealbaUser: "rfuentealba"
    Accepted Answer
    Hello,
    If you are not running a RapidMiner Server process, you can delete those files safely. That's why they are temporary.
    However, if you are running a process, you may want to stop. RapidMiner itself doesn't generate these files, as far as I can recall. (I may be wrong, though).
    All the best,
    Rod.
    lzuUser: "lzu"
    OP
    Thanks @rfuentealba
    I've deleted those files, but I'm not sure there's going to be a problem.Let me see if these files will be generated again.
    All the best,
    LiuWenlong
    These are definitely not from RM Server. You can delete them, but it's probably a waste of time. Linux generates hundreds of tmp files in a given session
    lzuUser: "lzu"
    OP
    @SGolbert Yes, they do look like they're linux-generated, not RM servers.
