🎉Community Raffle - Win $25
Join and Win
Air Flow around a Car
User: "kpk"
Altair Community Member
Updated by kpk
I am Trying to simulate a Car moving on a Ground/Road with velocities around 50 to 100 k mph, i have attached BCs for reference
are the BCs correct to study the Air flow around Car
1 - 5 of 51
    User: "acupro"
    Altair Employee
    Updated by acupro
    That seems reasonable.  You may want to make the domain larger - so more distance from the car to the side/top boundaries.  The flow around the car won't necessarily be symmetric, so you may lose some information with the symmetry approximation.
    User: "kpk"
    OP
    Updated by kpk
    Thanks for the feed back
    User: "kpk"
    OP
    Updated by kpk
    Is the Turbulence equation SA ok for this kind of simulation or any other should i use ?
    User: "kpk"
    OP
    Updated by kpk
    At the inlet should i give Average velocity or Directional Velocity (X/Y/Z) with respect to Axis ?
    is the Turbulence equation SA ok for this kind of simulation or any other should i use ?
    User: "acupro"
    Altair Employee
    Updated by acupro
    Probably directional (cartesian or normal) velocity is better, and you'll also need to define the turbulence quantities at the inlet.
    Interesting question - some of it depends on what level of fidelity/accuracy you want from the calculation.  Most papers/publications report the need for transient and maybe a DES approach.  AcuSolve supports SA-DES and SST-DES.
