Assign Agent through Schedule Process Operator
Updated by Jocelyn
Hi I need to configure a crawling process that gets the pages I'm going to crawl and then schedules a process on a given agent on RM Server.
The current Schedule Process doesn't give me the option to decide on which agent the process is going to be running.
The reason I need it to be dynamic is that I wan't to use an agent schedule that is capable of running 4 instances at the same time and the amount of pages is constantly increasing.
Inside my main process I have rules to delay the execution if I notice I'm being blocked due to excessive visits to certain domain.
Can anybody help me? Or can we schedule an update on this operator?
1 - 4 of
41
@mmichel, @mschmitz and @sgenzer
Thanks!! in fact once I select the process I wan't to execute the Q's appear. I know understand why it may only appear once you decided on which server you are going to work but It doesn't seem as intuitive as it should. Or maybe if the help said something about the dynamic loading of that expert parameter may help.
But your help I can confirm RM Server an Studio are capable of managing my need.
1 - 2 of
21
Martin
