Age
User: "paolamzavarce"
New Altair Community Member
Updated by Jocelyn
Hi! I am trying to create an atrribute which contains the age of a person since de day of birth to Agust 8 1990. Does anybody know how to do it?
1 - 2 of 21
    User: "YYH"
    Altair Employee
    Updated by YYH
    Hi @paolamzavarce
    "Generate Attribute" operator is your best friend :) You can use date_diff() function in the formula to calculate the gap between the birthday and Aug 8 1990. Just make sure date_diff is applied to two dates. And it will return the time difference in milliseconds. You can convert into years by rescaling.
    Cheers,
    YY
    User: "YYH"
    Altair Employee
    <?xml version="1.0" encoding="UTF-8"?><process version="9.3.001">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="2001"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value="yhuang@rapidminer.com"/>
        <parameter key="process_duration_for_mail" value="1"/>
        <parameter key="encoding" value="SYSTEM"/>
        <process expanded="true">
          <operator activated="true" class="retrieve" compatibility="9.3.001" expanded="true" height="68" name="Retrieve Customer Data" width="90" x="112" y="34">
            <parameter key="repository_entry" value="//Samples/Templates/Churn Modeling/Customer Data"/>
          </operator>
          <operator activated="true" class="generate_attributes" compatibility="9.3.001" expanded="true" height="82" name="Generate Attributes" width="90" x="313" y="34">
            <list key="function_descriptions">
              <parameter key="NEW_AGE" value="date_diff(CustomerSince,date_now())/1000/60/60/24/365"/>
            </list>
            <parameter key="keep_all" value="true"/>
          </operator>
          <connect from_op="Retrieve Customer Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
          <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
