<?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value="yhuang@rapidminer.com"/> <parameter key="process_duration_for_mail" value="1"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.3.001" expanded="true" height="68" name="Retrieve Customer Data" width="90" x="112" y="34"> <parameter key="repository_entry" value="//Samples/Templates/Churn Modeling/Customer Data"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.3.001" expanded="true" height="82" name="Generate Attributes" width="90" x="313" y="34"> <list key="function_descriptions"> <parameter key="NEW_AGE" value="date_diff(CustomerSince,date_now())/1000/60/60/24/365"/> </list> <parameter key="keep_all" value="true"/> </operator> <connect from_op="Retrieve Customer Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
