Explanation of KNNClassificationModel.java ?
hi,
I know Rapidminer have documentation about the KNN algorithm in the following link
https://github.com/rapidminer/rapidminer-studio/blob/master/src/main/java/com/rapidminer/operator/learner/lazy/KNNClassificationModel.javawhich means the KNN algorithm is also derived from the Java project right ?.
can anyone explain the algorithm in a simpler language ?, maybe like Pseudocode? or easier to understand.
because I see a slight difference with the usual KNN algorithm. I have asked the difference here.
https://community.rapidminer.com/discussion/55442/how-rapidminer-handle-same-distance-for-knn-algorithm#latest
Or can it be said that if there is an equal distance, then Rapidminer takes a label that is in the same order as the first queue?
thanks in advance for your help..
1 - 1 of
11
https://github.com/rapidminer/rapidminer-studio/tree/master/src/main/java/com/rapidminer/operator/learner/lazy
You will see the exact java code:
Scott
