1 - 2 of
21
@GINEER, when you add a learner to your process, you can right click on it and select operator info. This will tell you what kind of attributes are compatible. Make sure that you look carefully because at there are operators like Random Forest that can be used for regression but it might not be obvious at first just by looking at the defaults.
1 - 1 of
11
Based on my understanding Bayesian boosting works for classification problem.
