Hi everyone,
I'm very new in Rapidminer and just found difficulty here. I am conducting a loop process for a model, says 10 iterations and calculate the accuracy performance. However, the result shows only the averaged accuracy or final accuracy. I need the list of accuracy (which is contains 10 accuracies) in order to further check using statistical software like SPSS.
Is it possible to obtain accuracy list of my process using rapidminer?
Below is the averaged accuracy sample. Thanks for your kind response
