Altair RISE
Nominate Yourself Now!
How to use logistic regression for multi-class classification in rapidminer?
User: "mahsa_d1992"
New Altair Community Member
Updated by Jocelyn
Hi. I have a dataset which has nominal values. Also, the column I want to use as prediction is divided into 3 classes. I do not know how to use logistic regression in this state?
1 - 4 of 41
    User: "Telcontar120"
    Logistic regression only works with binominal (2-class) labels.  However, the Generalized Linear Model operator has a multinomial regression solver which is suitable for 3-class labels (or more).
    There is a sample process for it available in the operator help that should guide you.
    There are also many other ML operators that can handle multinomial labels.
    User: "varunm1"
    Hello @Telcontar120
    Is the solution suggested in your post similar to the multinomial logistic regression in python? I generally use python for this. I feel they might be similar but just want your insight.
    Also, we can try polynomial to binomial (One Vs All) and apply logistic regression on that directly.
    @varunm1 this is more of a question for @mschmitz but as far as I know, the multinomial GLM in RapidMiner would be very similar to the multinomial LR python function.
    The one-vs-all-other method is a workaround but isn't suitable if you really do want simultaneous predictions for multiple classes.
    User: "varunm1"
    Updated by varunm1
    Thanks Brian.
