GLM: weights vs. coefficients
kypexin
kypexin New Altair Community Member
edited November 2024 in Community Q&A
Hi miners,
I am training GLM model for binary classification, so basically I perform logistic regression.
My question is, how do I interpret the relation between GLM model weights output and regression coefficients?
In many cases, they are exactly the same, but some differ, and some on a very high magnitude. For example, for one feature weight and regression coefficient both equal 1.841; then for another feature I observe weight 0.328 while regression coefficient is 0.0002; yet for another feature weight is -0.617 and coefficient is -0.001.
(I use regularisation so the whole coefficients / weights range is not that big, let's say roughly between 2 and -2).
Welcome!
Best Answers
  • IngoRM
    IngoRM New Altair Community Member
    Answer ✓
    Hi,
    Where are the weights coming from?  I assume from the weights port of the GLM operator?  And are you looking at the "standardized" coefficients?  The weights are simply the standardized coefficients and should be the same if you use the weights port of the GLM...
    Hope this helps,
    Ingo
  • Telcontar120
    Telcontar120 New Altair Community Member
    Answer ✓
    @kypexin Sorry for the confusion!  I definitely misunderstood your initial question.  Hopefully I can be more helpful here :smile:
    If you are using the score on new raw data, then you will want to use the normal coefficients.  The standardized coefficients are adjusted so they are comparable but they won't work to generate a score (unless you have normalized all the input data based on standard errors, which is very unlikely).
Answers
  • IngoRM
    Answer ✓
    Hi,
    Hope this helps,
    Ingo
  • kypexin
    Hi @Telcontar120
    Thanks for the example; it makes a clear point, however this is not exactly what I was asking for. I am not trying to compare GLM and LR, but actually I have just one GLM model where I am comparing model coefficients with feature weights. I think Ingo's answer cleared it pretty well.
  • kypexin
    Hi @IngoRM
    Thanks for an advise, I was looking at the first column of coefficients (not standardized). In fact, std. coefficients and weights from GLM weights output port are the same, so I have my question answered.
    However, I have now the second question: if I use derived coefficients for a regression equation (which for example I then put into code to make predictions on new data), should I actually use normal or standardized coefficients, or it won't make a difference? What I exactly mean, I am using the following formulas to calculate probability on new data:
    <div>p = exp(y*)/(1 + exp(y*)),
    where&nbsp;</div><div>y* = Log ( p / (1-p) ) = b0 + b1*x1 + b2*x2 + ... + bk*xk</div>
  • Telcontar120
    Answer ✓
  • kypexin
    Thanks @Telcontar120 - pretty clear.
Welcome!
Welcome!
