🎉Community Raffle - Win $25
Join and Win
How can i do an if that must meet two conditions, if there is no "and" function?
User: "cdaponte"
New Altair Community Member
Updated by Jocelyn
I´m using the operator Generate Attributes and i want to generate an attribute from 2 existing ones, and the problem is that i have to use an if expression but it must meet two conditions. As far as i´m concerned there is not a function like "AND" o yes?
Thank you!
1 - 6 of 61
    User: "sgenzer"
    Altair Employee
    hi @cdaponte yes you can use || for OR and && for AND
    Scott
    User: "cdaponte"
    OP
    Yes! But it doesn´t work for me, i don´t know why. Maybe because one attribute that i use in the if is an attribute that i create before?
    User: "varunm1"
    Updated by varunm1
    @cdaponte do you mean, you are creating an attribute in the generate attribute and using it in the same generate attribute operator?
    Can you provide your XML code for this process? It is available in XML window (View --> Show Panel --> XML)
    User: "cdaponte"
    OP
    if(contains(Tercerizado,"WEISFELD"),"ESTUDIO JUDICIAL",
    if(contains(Tercerizado,"QUIEBRA"),"ESTUDIO JUDICIAL",
    if(contains(Tercerizado,"Weisfeld"),"ESTUDIO JUDICIAL",
    if(contains(Tercerizado,"LLECI"),"ESTUDIO JUDICIAL",
    if(contains(Tercerizado,"SAGUES"),"ESTUDIO JUDICIAL",
    if(contains(Tercerizado,"HADADD"),"ESTUDIO JUDICIAL",
    if(equals(Tercerizado,"JUDICIAL"),"ESTUDIO JUDICIAL",
    if((Tercerizado=="MORA TARDIA") && ("Producto Genérico"== "CBU- NO BARRIDO"),"MORA TARDIA-CBU-NO BARRIDO",
    if((Tercerizado=="MORA TARDIA") && ("Producto Genérico"=="PV"), "MORA TARDIA-PV","ESTUDIO EXTRAJUDICIAL")))))))))
    It appears that the expression is correct, but the results are not the expected, the 2 last if does not work. "Producto Genérico" is an attribute that i previously created.
    User: "varunm1"
    Accepted Answer
    Updated by varunm1
    Is the attribute type of "Tercerizado"  text? I see that "contains" only works for attribute type Text. If it is polynomial, you can use nominal to text operator to convert the attribute type to text. Also the text in quotations is case sensitive.
    I tried && operator with a new attribute created and it works fine for me. If it still doesn't work, try creating "producto Generico" in generate attribute and then again use another generate attribute to create this "if" based column after producto generico. Test and see how it goes.
    User: "tftemme"
    Accepted Answer
    Hi @cdaponte
    The problem with the second conditions in the last 2 if conditions is, that you have put the Producto Genérico into "". So RapidMiner takes "Producto Genérico) as a normal String (and not using it as the attribute) and compare it to the other String ("PV"). This obviously results always in false. So although the syntax of the expression is correct (thats the only thing RM can check), the condition will never be fulfilled.
    Just change "Producto Genérico" to [Producto Genérico] and your if conditions should work.
    Best regards,
    Fabian
