1 - 3 of
31
Hello @nikhitha
Sorry, a bit confused, Are you trying to read data from an XML file or create a process in RM from an existing XML process file?
The read XML operator is used to read attributes into RapidMiner similar to read CSV and read Excel. If you have an XML code for a process then, you need to copy the code from XML file (open it in notepad) and then paste it in the XML window of rapidminer. To access XML window, you need to go through (View --> Show Panel --> XML). Once you paste the code in XML window, you need to click on the green tick mark on XML window, this will show you the workflow (Process flow).
Please inform if you need more information or this not what you are asking about.
@nikhitha
I think that if you just copy the XML code and paste it into Design panel, the flow will appear.
MarlaBot
