Altair RISE
Nominate Yourself Now!
Stop word removal with operator toolbox extract topics from data(LDA)
User: "Joris"
New Altair Community Member
Updated by Jocelyn
Hi there - first time asking a question, and new to rapidminer.
I have an excel file with around a text field and 740 rows of data.  Each cell contains a few paragraphs of text.  I ran the operator toolbox extract topics from data (LDA) on it, and it works very well in topic discovery.  But it doesn't remove the stopwords, so I end up with a large group of topics clustered around stopwords.
I've tried a few different ways of removing the stopwords (and then still be able to run the LDA operator on it (it can take documents or a text field in a dataset).
Can anyone assist in removing the stopwords?
Below is my XML code.  Thanks a lot!
<?xml version="1.0" encoding="UTF-8"?><process version="9.3.001">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process">
    <parameter key="logverbosity" value="init"/>
    <parameter key="random_seed" value="2001"/>
    <parameter key="send_mail" value="never"/>
    <parameter key="notification_email" value=""/>
    <parameter key="process_duration_for_mail" value="30"/>
    <parameter key="encoding" value="SYSTEM"/>
    <process expanded="true">
      <operator activated="true" class="read_excel" compatibility="9.3.001" expanded="true" height="68" name="Read Excel" width="90" x="45" y="85">
        <parameter key="excel_file" value="C:\Users\vande\Google Drive (jorisv@clearoutcomes.net)\IPDET Course Text Analytics\Demonstrations - Practical exercises\Exercise 5 Topic Modelling\PovertyActionLab.xlsx"/>
        <parameter key="sheet_selection" value="sheet number"/>
        <parameter key="sheet_number" value="1"/>
        <parameter key="imported_cell_range" value="A1"/>
        <parameter key="first_row_as_names" value="true"/>
        <list key="annotations"/>
        <parameter key="date_format" value=""/>
        <parameter key="time_zone" value="SYSTEM"/>
        <parameter key="locale" value="English (United States)"/>
        <parameter key="read_all_values_as_polynominal" value="false"/>
        <list key="data_set_meta_data_information"/>
        <parameter key="read_not_matching_values_as_missings" value="true"/>
        <parameter key="datamanagement" value="double_array"/>
        <parameter key="data_management" value="auto"/>
      </operator>
      <operator activated="true" class="nominal_to_text" compatibility="9.3.001" expanded="true" height="82" name="Nominal to Text" width="90" x="179" y="85">
        <parameter key="attribute_filter_type" value="single"/>
        <parameter key="attribute" value="PolicyIssues"/>
        <parameter key="attributes" value=""/>
        <parameter key="use_except_expression" value="false"/>
        <parameter key="value_type" value="nominal"/>
        <parameter key="use_value_type_exception" value="false"/>
        <parameter key="except_value_type" value="file_path"/>
        <parameter key="block_type" value="single_value"/>
        <parameter key="use_block_type_exception" value="false"/>
        <parameter key="except_block_type" value="single_value"/>
        <parameter key="invert_selection" value="false"/>
        <parameter key="include_special_attributes" value="false"/>
      </operator>
      <operator activated="true" class="operator_toolbox:lda_exampleset" compatibility="2.1.000" expanded="true" height="124" name="Extract Topics from Data (LDA)" width="90" x="380" y="136">
        <parameter key="text_attribute" value="PolicyIssues"/>
        <parameter key="number_of_topics" value="6"/>
        <parameter key="use_alpha_heuristics" value="true"/>
        <parameter key="alpha_sum" value="0.1"/>
        <parameter key="use_beta_heuristics" value="true"/>
        <parameter key="beta" value="0.01"/>
        <parameter key="optimize_hyperparameters" value="true"/>
        <parameter key="optimize_interval_for_hyperparameters" value="10"/>
        <parameter key="top_words_per_topic" value="10"/>
        <parameter key="iterations" value="1000"/>
        <parameter key="reproducible" value="true"/>
        <parameter key="enable_logging" value="false"/>
        <parameter key="use_local_random_seed" value="false"/>
        <parameter key="local_random_seed" value="1992"/>
      </operator>
      <connect from_op="Read Excel" from_port="output" to_op="Nominal to Text" to_port="example set input"/>
      <connect from_op="Nominal to Text" from_port="example set output" to_op="Extract Topics from Data (LDA)" to_port="exa"/>
      <connect from_op="Extract Topics from Data (LDA)" from_port="exa" to_port="result 1"/>
      <connect from_op="Extract Topics from Data (LDA)" from_port="top" to_port="result 2"/>
      <portSpacing port="sink_result 3" spacing="0"/>
    </process>
  </operator>
</process>
1 - 9 of 91
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    Hi @Joris,
    can you maybe try this?
    <?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"><br>  <context><br>    <input/><br>    <output/><br>    <macros/><br>  </context><br>  <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process"><br>    <parameter key="logverbosity" value="init"/><br>    <parameter key="random_seed" value="2001"/><br>    <parameter key="send_mail" value="never"/><br>    <parameter key="notification_email" value=""/><br>    <parameter key="process_duration_for_mail" value="30"/><br>    <parameter key="encoding" value="SYSTEM"/><br>    <process expanded="true"><br>      <operator activated="true" class="read_excel" compatibility="9.3.001" expanded="true" height="68" name="Read Excel" width="90" x="45" y="85"><br>        <parameter key="excel_file" value="C:\Users\vande\Google Drive (jorisv@clearoutcomes.net)\IPDET Course Text Analytics\Demonstrations - Practical exercises\Exercise 5 Topic Modelling\PovertyActionLab.xlsx"/><br>        <parameter key="sheet_selection" value="sheet number"/><br>        <parameter key="sheet_number" value="1"/><br>        <parameter key="imported_cell_range" value="A1"/><br>        <parameter key="encoding" value="SYSTEM"/><br>        <parameter key="first_row_as_names" value="true"/><br>        <list key="annotations"/><br>        <parameter key="date_format" value=""/><br>        <parameter key="time_zone" value="SYSTEM"/><br>        <parameter key="locale" value="English (United States)"/><br>        <parameter key="read_all_values_as_polynominal" value="false"/><br>        <list key="data_set_meta_data_information"/><br>        <parameter key="read_not_matching_values_as_missings" value="true"/><br>        <parameter key="datamanagement" value="double_array"/><br>        <parameter key="data_management" value="auto"/><br>      </operator><br>      <operator activated="true" class="nominal_to_text" compatibility="9.3.001" expanded="true" height="82" name="Nominal to Text" width="90" x="179" y="85"><br>        <parameter key="attribute_filter_type" value="single"/><br>        <parameter key="attribute" value="PolicyIssues"/><br>        <parameter key="attributes" value=""/><br>        <parameter key="use_except_expression" value="false"/><br>        <parameter key="value_type" value="nominal"/><br>        <parameter key="use_value_type_exception" value="false"/><br>        <parameter key="except_value_type" value="file_path"/><br>        <parameter key="block_type" value="single_value"/><br>        <parameter key="use_block_type_exception" value="false"/><br>        <parameter key="except_block_type" value="single_value"/><br>        <parameter key="invert_selection" value="false"/><br>        <parameter key="include_special_attributes" value="false"/><br>      </operator><br>      <operator activated="true" class="text:data_to_documents" compatibility="9.1.000-SNAPSHOT" expanded="true" height="68" name="Data to Documents" width="90" x="313" y="85"><br>        <parameter key="select_attributes_and_weights" value="false"/><br>        <list key="specify_weights"/><br>      </operator><br>      <operator activated="true" class="loop_collection" compatibility="9.3.001" expanded="true" height="82" name="Loop Collection" width="90" x="447" y="85"><br>        <parameter key="set_iteration_macro" value="false"/><br>        <parameter key="macro_name" value="iteration"/><br>        <parameter key="macro_start_value" value="1"/><br>        <parameter key="unfold" value="false"/><br>        <process expanded="true"><br>          <operator activated="true" class="text:tokenize" compatibility="9.1.000-SNAPSHOT" expanded="true" height="68" name="Tokenize" width="90" x="313" y="34"><br>            <parameter key="mode" value="non letters"/><br>            <parameter key="characters" value=".:"/><br>            <parameter key="language" value="English"/><br>            <parameter key="max_token_length" value="3"/><br>          </operator><br>          <operator activated="true" class="text:filter_stopwords_english" compatibility="9.1.000-SNAPSHOT" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="447" y="34"/><br>          <connect from_port="single" to_op="Tokenize" to_port="document"/><br>          <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/><br>          <connect from_op="Filter Stopwords (English)" from_port="document" to_port="output 1"/><br>          <portSpacing port="source_single" spacing="0"/><br>          <portSpacing port="sink_output 1" spacing="0"/><br>          <portSpacing port="sink_output 2" spacing="0"/><br>        </process><br>      </operator><br>      <operator activated="true" class="text:documents_to_data" compatibility="9.1.000-SNAPSHOT" expanded="true" height="82" name="Documents to Data" width="90" x="581" y="85"><br>        <parameter key="add_meta_information" value="true"/><br>        <parameter key="datamanagement" value="double_sparse_array"/><br>        <parameter key="data_management" value="auto"/><br>        <parameter key="use_processed_text" value="true"/><br>      </operator><br>      <operator activated="true" class="operator_toolbox:lda_exampleset" compatibility="2.3.000-SNAPSHOT" expanded="true" height="124" name="Extract Topics from Data (LDA)" width="90" x="715" y="85"><br>        <parameter key="text_attribute" value="PolicyIssues"/><br>        <parameter key="number_of_topics" value="6"/><br>        <parameter key="use_alpha_heuristics" value="true"/><br>        <parameter key="alpha_sum" value="0.1"/><br>        <parameter key="use_beta_heuristics" value="true"/><br>        <parameter key="beta" value="0.01"/><br>        <parameter key="optimize_hyperparameters" value="true"/><br>        <parameter key="optimize_interval_for_hyperparameters" value="10"/><br>        <parameter key="top_words_per_topic" value="10"/><br>        <parameter key="iterations" value="1000"/><br>        <parameter key="reproducible" value="true"/><br>        <parameter key="enable_logging" value="false"/><br>        <parameter key="use_local_random_seed" value="false"/><br>        <parameter key="local_random_seed" value="1992"/><br>      </operator><br>      <connect from_op="Read Excel" from_port="output" to_op="Nominal to Text" to_port="example set input"/><br>      <connect from_op="Nominal to Text" from_port="example set output" to_op="Data to Documents" to_port="example set"/><br>      <connect from_op="Data to Documents" from_port="documents" to_op="Loop Collection" to_port="collection"/><br>      <connect from_op="Loop Collection" from_port="output 1" to_op="Documents to Data" to_port="documents 1"/><br>      <connect from_op="Documents to Data" from_port="example set" to_op="Extract Topics from Data (LDA)" to_port="exa"/><br>      <connect from_op="Extract Topics from Data (LDA)" from_port="exa" to_port="result 1"/><br>      <connect from_op="Extract Topics from Data (LDA)" from_port="top" to_port="result 2"/><br>      <portSpacing port="source_input 1" spacing="0"/><br>      <portSpacing port="sink_result 1" spacing="0"/><br>      <portSpacing port="sink_result 2" spacing="0"/><br>      <portSpacing port="sink_result 3" spacing="0"/><br>    </process><br>  </operator><br></process><br><br>
    BR,
    Martin
    User: "Joris"
    OP
    Hi Martin,
    thanks so much for the fast reply - really appreciated.  Your code was exactly what I was looking for - worked like a charm,  I only had to add the text attribute in the documents to data operator (which was PolicyIssues).
    I also found another way, without the step of getting the documents back to data, by using the extract topics from documents operator, so that I could do away with the documents to data one.
    see below.
    Thanks again for your fast and expert advice.  Have a great weekend
    Joris
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
          </operator>
          </operator>
          <operator activated="true" class="text:data_to_documents" compatibility="8.2.000" expanded="true" height="68" name="Data to Documents" width="90" x="313" y="85">
          </operator>
              <operator activated="true" class="text:tokenize" compatibility="8.2.000" expanded="true" height="68" name="Tokenize" width="90" x="313" y="34">
              </operator>
              <operator activated="true" class="text:filter_stopwords_english" compatibility="8.2.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="447" y="34"/>
            </process>
          </operator>
          <operator activated="true" class="operator_toolbox:lda" compatibility="2.1.000" expanded="true" height="124" name="Extract Topics from Documents (LDA)" width="90" x="581" y="85">
            <parameter key="number_of_topics" value="10"/>
            <parameter key="top_words_per_topic" value="5"/>
            <parameter key="reproducible" value="false"/>
            <parameter key="include_meta_data" value="true"/>
          </operator>
          <connect from_op="Loop Collection" from_port="output 1" to_op="Extract Topics from Documents (LDA)" to_port="col"/>
          <connect from_op="Extract Topics from Documents (LDA)" from_port="exa" to_port="result 1"/>
          <connect from_op="Extract Topics from Documents (LDA)" from_port="top" to_port="result 2"/>
        </process>
      </operator>
    </process>
    Hi @Joris ,
    happy to help! LDA is "my baby", since i wrote the operator. Feel free to @ me whenever you have a question on LDA. That triggers an email notification.
    Best,
    Martin
    User: "RickB"
    Hello @mschmitz,
    I am fairly new to RapidMiner. I recently ran the operator toolbox extract topics from data (LDA) on a set of data. I set it up to remove URLs, stopwords, and very short words. Is there a way to see the number of terms removed in the results?
    Thank you!
    Hi @RickB,
    not that i am aware about. @kayman do you know a trick?
    Cheers,
    martin
    User: "scott_reeves"
    Martin, is there a way to insert an operator to strip the stopwords?  I am not coding proficient so I am a drag and drop cripple!  I have a process where I have been preprocessing prior to K-medoid clustering.  I think LDA may be a better solution but I still need to strip stopwords, filter by length etc.
    beg my pardon, I am not sure exactly what the problem is?
    Best,
    Martin
    when I send the preprocessed text to the LDA from data operator it doesn't like the format, the operator can's see the processed text and if I take out the processing operator I don't see a way to strip the stop words.
    @scott_reeves I assume you're doing transformations to the documents (Filter stopwords, etc.) and then using Documents to data to send it to the LDA? If that's the case you'll need to check the 'Use Processed Text' option in the parameters for the Documents to Data operator. I built something similar to this a while back. Let me know if you need anymore help?
