🎉Community Raffle - Win $25
Join and Win
Limitations with the RapidMiner Educational License Program
User142977User: "User142977"
New Altair Community Member
Updated by Jocelyn
Hi. I'm trying to run a basic Spearman's correlation matrix on a 8 variable 1030 record dataset, but I receive the error "demo license does not allow to process datasets with a size that exceeds 250 ....."
I assume your free education license has major limitations of record sizes? Under this program can I assess any other RapidMiner license?
Thanks in advance for this clarification.
Ray
1 - 3 of 31
    Marco_BoeckUser: "Marco_Boeck"
    Accepted Answer
    Hi,
    Our educational license actually comes with no limitations. In your case, that particular operator is not an operator provided by RapidMiner, but rather an extension (you can see it in the header of the help panel to which extension an operator belongs). That extension seems to use a licensing mechanism as well, so you'd have to contact the author of that extension.
    Regards,
    Marco
    Thanks Marco for that information -- appreciated.
    NikouyUser: "Nikouy"
    Updated by Nikouy
    After having read https://docs.rapidminer.com/9.2/server/install/license-limits.html I have some questions about limiting the logical number of processors when using RM Server and an Educational License.
    1) Can I have multiple Job agents (multiple logical processors each) connected to the same server instance, and each job agent make use of 8 logical processors?
    2) If running multiple processes in the same job agent, can each job container make use of 8 logical processors?
    Is the number of processors used determined by the kind of operators I am using, and the maximum defined in RM Studio settings, or in RM server?
    Regarding memory limits, I understand that the total memory among all my job containers cannot exceed 64GB, correct?
    Thanks,
    Nicolas
