🎉Community Raffle - Win $25
Join and Win
Averaging attribute weights
User: "varunm1"
New Altair Community Member
Updated by Jocelyn
Hello,
I am extracting attribute weights from different folds of cross-validation. I have 5 files in attribute weights format, is it possible to average the weights based on attribute name in these files in a repository?
I tried converting weights to data and aggregate them in excel file, but I am not sure how to convert this example set back into attribute weights format as this example set has attribute name and the corresponding weight of that attribute. Please inform if you need more information. I attached the attribute and weights in excel format.
@IngoRM or @mschmitz any suggestion here?
Thanks
1 - 2 of 21
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    Hi @varunm1
    @tftemme had this use case a time ago. I think he added an operator called Example Set to Weights to Converters extension to cover this.
    Best,
    Martin
    User: "varunm1"
    OP
    Thanks, Martin and @tftemme. That worked like a gem :smile:
