1 - 9 of
91
There is really no such thing as a multiclass ROC curve. Each of of these curves is likely generated by a "one vs all other" approach (e.g., when looking at class A, the curve is a vs not-A, and so on). You can only do this manually in RapidMiner by linking multiple performance operators after building different models on different labels (you need a binominal label for each class using the one vs all others approach). Then you can have a curve for each of the classes separately).
@sgenzer I think Compare ROC doesn't help in this circumstances since it requires you to have the same label for all the inner learners which are run at the same time.
But if someone else knows a better way to do what the OP is asking, I would be very interested.
Hello @Telcontar120 and @mschmitz
Just a thought, Can't we relabel one vs all manually (converting to binomial) and then run the validation methods on different one vs all to get ROC curves and average the performance metrics? I am not sure if there is an easier way in RM.
Thanks,
Varun
Thanks,
Varun
@Telcontar120 you are correct. My bad. My eyes went right over the 'multi-class' requirement. Thx.
@varunm1 That is the same as what I suggested, but you have to do it 6 times if you have 6 classes (6 different one vs all definitions, then run the model and store the ROC area, and then average them all at the end).
Thanks, @Telcontar120. Sorry my bad, read it differently. But in the long run, if there are many classes, this doesn't seem to be a feasible option if people need multiple ROC curves in case of multiclass classification. But I also see very less AUC or ROC comparisons in research for multiclass classification.
@varunm1, The Problem is How to do it, I mean one vs all? Could you show me the Process in Rapidminer!
@MunchCrunch19
you need to manually relabel and generate multiple datasets,
For example, you have three classes A, B, C. In the first dataset you will keep A but B and C are relabelled as D (now it is converted to binomial (A and D ). Similarly, you will keep B and relabel A and C as E which gives you a second dataset with classes B and E and soon. As you have 6 classes you will have 6 datasets.
There might be other better and simple ways. But this is what I did using IRIS dataset that has 3 classes. Check the expression in generate attribute where I am relabelling and converting to binomial classification. XML code below. The figure for reference below. You get multiple AUC values.
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process">
<parameter key="logverbosity" value="init"/>
<parameter key="random_seed" value="2001"/>
<parameter key="send_mail" value="never"/>
<parameter key="notification_email" value=""/>
<parameter key="process_duration_for_mail" value="30"/>
<parameter key="encoding" value="SYSTEM"/>
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve Iris" width="90" x="45" y="85">
<parameter key="repository_entry" value="//Samples/data/Iris"/>
</operator>
<operator activated="true" class="multiply" compatibility="9.2.001" expanded="true" height="124" name="Multiply" width="90" x="179" y="85"/>
<operator activated="true" class="generate_attributes" compatibility="9.2.001" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="313" y="136">
<list key="function_descriptions">
<parameter key="Binomial_Labels_Generated" value="if(label == "Iris-virginica", "A", (if(label == "Iris-versicolor","A",label)))"/>
</list>
<parameter key="keep_all" value="true"/>
</operator>
<operator activated="true" class="generate_attributes" compatibility="9.2.001" expanded="true" height="82" name="Generate Attributes" width="90" x="313" y="34">
<parameter key="Binomial_Labels_Generated" value="if(label == "Iris-virginica", "A", (if(label == "Iris-setosa","A",label)))"/>
</list>
</operator>
<operator activated="true" class="select_attributes" compatibility="9.2.001" expanded="true" height="82" name="Select Attributes" width="90" x="447" y="34">
<parameter key="attribute_filter_type" value="single"/>
<parameter key="attribute" value="label"/>
<parameter key="attributes" value=""/>
<parameter key="use_except_expression" value="false"/>
<parameter key="value_type" value="attribute_value"/>
<parameter key="use_value_type_exception" value="false"/>
<parameter key="except_value_type" value="time"/>
<parameter key="block_type" value="attribute_block"/>
<parameter key="use_block_type_exception" value="false"/>
<parameter key="except_block_type" value="value_matrix_row_start"/>
<parameter key="invert_selection" value="true"/>
<parameter key="include_special_attributes" value="true"/>
</operator>
<operator activated="true" class="set_role" compatibility="9.2.001" expanded="true" height="82" name="Set Role" width="90" x="581" y="34">
<parameter key="attribute_name" value="Binomial_Labels_Generated"/>
<parameter key="target_role" value="label"/>
<list key="set_additional_roles"/>
</operator>
<operator activated="true" class="concurrency:cross_validation" compatibility="9.2.001" expanded="true" height="145" name="Cross Validation" width="90" x="715" y="34">
<parameter key="split_on_batch_attribute" value="false"/>
<parameter key="leave_one_out" value="false"/>
<parameter key="number_of_folds" value="10"/>
<parameter key="sampling_type" value="automatic"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<parameter key="enable_parallel_execution" value="true"/>
<operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.2.001" expanded="true" height="103" name="Decision Tree" width="90" x="112" y="34">
<parameter key="criterion" value="gain_ratio"/>
<parameter key="maximal_depth" value="10"/>
<parameter key="apply_pruning" value="true"/>
<parameter key="confidence" value="0.1"/>
<parameter key="apply_prepruning" value="true"/>
<parameter key="minimal_gain" value="0.01"/>
<parameter key="minimal_leaf_size" value="2"/>
<parameter key="minimal_size_for_split" value="4"/>
<parameter key="number_of_prepruning_alternatives" value="3"/>
</operator>
<connect from_port="training set" to_op="Decision Tree" to_port="training set"/>
<connect from_op="Decision Tree" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
<portSpacing port="sink_model" spacing="0"/>
<portSpacing port="sink_through 1" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="9.2.001" expanded="true" height="82" name="Apply Model" width="90" x="112" y="34">
<parameter key="create_view" value="false"/>
</operator>
<operator activated="true" class="performance_binominal_classification" compatibility="9.2.001" expanded="true" height="82" name="Performance" width="90" x="246" y="34">
<parameter key="main_criterion" value="first"/>
<parameter key="accuracy" value="true"/>
<parameter key="classification_error" value="false"/>
<parameter key="kappa" value="false"/>
<parameter key="AUC (optimistic)" value="false"/>
<parameter key="AUC" value="true"/>
<parameter key="AUC (pessimistic)" value="false"/>
<parameter key="precision" value="false"/>
<parameter key="recall" value="false"/>
<parameter key="lift" value="false"/>
<parameter key="fallout" value="false"/>
<parameter key="f_measure" value="false"/>
<parameter key="false_positive" value="false"/>
<parameter key="false_negative" value="false"/>
<parameter key="true_positive" value="false"/>
<parameter key="true_negative" value="false"/>
<parameter key="sensitivity" value="false"/>
<parameter key="specificity" value="false"/>
<parameter key="youden" value="false"/>
<parameter key="positive_predictive_value" value="false"/>
<parameter key="negative_predictive_value" value="false"/>
<parameter key="psep" value="false"/>
<parameter key="skip_undefined_labels" value="true"/>
<parameter key="use_example_weights" value="true"/>
</operator>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="performance 1"/>
<portSpacing port="source_model" spacing="0"/>
<portSpacing port="source_test set" spacing="0"/>
<portSpacing port="source_through 1" spacing="0"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="converters:roc_curve_2_example_set" compatibility="0.5.000" expanded="true" height="82" name="ROC Curve to ExampleSet" width="90" x="849" y="34">
<parameter key="Number of Points" value="500"/>
</operator>
<operator activated="true" class="select_attributes" compatibility="9.2.001" expanded="true" height="82" name="Select Attributes (2)" width="90" x="447" y="187">
</operator>
<operator activated="true" class="set_role" compatibility="9.2.001" expanded="true" height="82" name="Set Role (2)" width="90" x="581" y="187">
</operator>
<operator activated="true" class="concurrency:cross_validation" compatibility="9.2.001" expanded="true" height="145" name="Cross Validation (2)" width="90" x="715" y="187">
<operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.2.001" expanded="true" height="103" name="Decision Tree (2)" width="90" x="112" y="34">
</operator>
<connect from_port="training set" to_op="Decision Tree (2)" to_port="training set"/>
<connect from_op="Decision Tree (2)" from_port="model" to_port="model"/>
</process>
<operator activated="true" class="apply_model" compatibility="9.2.001" expanded="true" height="82" name="Apply Model (2)" width="90" x="112" y="34">
</operator>
<operator activated="true" class="performance_binominal_classification" compatibility="9.2.001" expanded="true" height="82" name="Performance (2)" width="90" x="246" y="34">
</operator>
<connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
<connect from_op="Performance (2)" from_port="performance" to_port="performance 1"/>
</process>
</operator>
<operator activated="true" class="generate_attributes" compatibility="9.2.001" expanded="true" height="82" name="Generate Attributes (3)" width="90" x="313" y="289">
<parameter key="Binomial_Labels_Generated" value="if(label == "Iris-setosa", "A", (if(label == "Iris-versicolor","A",label)))"/>
</list>
</operator>
<operator activated="true" class="select_attributes" compatibility="9.2.001" expanded="true" height="82" name="Select Attributes (3)" width="90" x="447" y="340">
</operator>
<operator activated="true" class="set_role" compatibility="9.2.001" expanded="true" height="82" name="Set Role (3)" width="90" x="581" y="340">
</operator>
<operator activated="true" class="concurrency:cross_validation" compatibility="9.2.001" expanded="true" height="145" name="Cross Validation (3)" width="90" x="715" y="340">
<operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.2.001" expanded="true" height="103" name="Decision Tree (3)" width="90" x="112" y="34">
</operator>
<connect from_port="training set" to_op="Decision Tree (3)" to_port="training set"/>
<connect from_op="Decision Tree (3)" from_port="model" to_port="model"/>
</process>
<operator activated="true" class="apply_model" compatibility="9.2.001" expanded="true" height="82" name="Apply Model (3)" width="90" x="112" y="34">
</operator>
<operator activated="true" class="performance_binominal_classification" compatibility="9.2.001" expanded="true" height="82" name="Performance (3)" width="90" x="246" y="34">
</operator>
<connect from_port="model" to_op="Apply Model (3)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (3)" to_port="unlabelled data"/>
<connect from_op="Apply Model (3)" from_port="labelled data" to_op="Performance (3)" to_port="labelled data"/>
<connect from_op="Performance (3)" from_port="performance" to_port="performance 1"/>
</process>
</operator>
<operator activated="true" class="converters:roc_curve_2_example_set" compatibility="0.5.000" expanded="true" height="82" name="ROC Curve to ExampleSet (3)" width="90" x="849" y="340">
</operator>
<operator activated="true" class="converters:roc_curve_2_example_set" compatibility="0.5.000" expanded="true" height="82" name="ROC Curve to ExampleSet (2)" width="90" x="849" y="238">
</operator>
<operator activated="true" class="concurrency:join" compatibility="9.2.001" expanded="true" height="82" name="Join" width="90" x="916" y="136">
<parameter key="remove_double_attributes" value="false"/>
<parameter key="join_type" value="outer"/>
<parameter key="use_id_attribute_as_key" value="false"/>
<list key="key_attributes">
<parameter key="false positive rate" value="false positive rate"/>
</list>
<parameter key="keep_both_join_attributes" value="false"/>
</operator>
<operator activated="true" class="concurrency:join" compatibility="9.2.001" expanded="true" height="82" name="Join (2)" width="90" x="1050" y="187">
</list>
</operator>
<operator activated="true" class="rename" compatibility="9.2.001" expanded="true" height="82" name="Rename" width="90" x="1251" y="136">
<parameter key="old_name" value="true positive rate (Mean)"/>
<parameter key="new_name" value="true Positive Iris-versicolor"/>
<list key="rename_additional_attributes">
<parameter key="true positive rate (Mean)_from_ES2" value="true positive Iris-Setosa"/>
<parameter key="true positive rate (Mean)_from_ES2_from_ES2" value="true Positive Iris-virginica"/>
</list>
</operator>
<connect from_op="Retrieve Iris" from_port="output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 2" to_op="Generate Attributes (2)" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 3" to_op="Generate Attributes (3)" to_port="example set input"/>
<connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Cross Validation" to_port="example set"/>
<connect from_op="Cross Validation" from_port="performance 1" to_op="ROC Curve to ExampleSet" to_port="performance"/>
<connect from_op="ROC Curve to ExampleSet" from_port="example set" to_op="Join" to_port="left"/>
<connect from_op="ROC Curve to ExampleSet" from_port="original" to_port="result 3"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Cross Validation (2)" to_port="example set"/>
<connect from_op="Cross Validation (2)" from_port="performance 1" to_op="ROC Curve to ExampleSet (2)" to_port="performance"/>
<connect from_op="Generate Attributes (3)" from_port="example set output" to_op="Select Attributes (3)" to_port="example set input"/>
<connect from_op="Select Attributes (3)" from_port="example set output" to_op="Set Role (3)" to_port="example set input"/>
<connect from_op="Set Role (3)" from_port="example set output" to_op="Cross Validation (3)" to_port="example set"/>
<connect from_op="Cross Validation (3)" from_port="performance 1" to_op="ROC Curve to ExampleSet (3)" to_port="performance"/>
<connect from_op="ROC Curve to ExampleSet (3)" from_port="example set" to_op="Join (2)" to_port="right"/>
<connect from_op="ROC Curve to ExampleSet (3)" from_port="original" to_port="result 4"/>
<connect from_op="ROC Curve to ExampleSet (2)" from_port="example set" to_op="Join" to_port="right"/>
<connect from_op="ROC Curve to ExampleSet (2)" from_port="original" to_port="result 1"/>
<connect from_op="Join" from_port="join" to_op="Join (2)" to_port="left"/>
<connect from_op="Join (2)" from_port="join" to_op="Rename" to_port="example set input"/>
<connect from_op="Rename" from_port="example set output" to_port="result 2"/>
<portSpacing port="sink_result 3" spacing="0"/>
<portSpacing port="sink_result 4" spacing="0"/>
<portSpacing port="sink_result 5" spacing="0"/>
</process>
</operator>
</process>
Here is the image for reference. I used multiple operators like Joins and Rename to get plots on the same figure. Once you run the process, you need to go to Example(Rename) and then select visualizations, here you need to get all the true positive rates (mean) and plot it using a line plot.
Here are the ROC curves in same plot.
Hope this helps
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"><context>
<input/>
<output/>
<macros/>
</context>
</operator>
</list>
</operator>
</list>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</operator>
</process>
</operator>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</operator>
</process>
</operator>
</list>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</operator>
</process>
</operator>
</operator>
</operator>
</list>
</operator>
</list>
</operator>
</list>
</operator>
</process>
</operator>
</process>
Hope this helps
@MunchCrunch19 Process and figures updated in the above post with clear distinction.
1 - 2 of
21
@MunchCrunch19
<context>
<input/>
<output/>
<macros/>
</context>
</operator>
</list>
</operator>
</list>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</operator>
</process>
</operator>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</operator>
</process>
</operator>
</list>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</operator>
</process>
</operator>
</operator>
</operator>
</list>
</operator>
</list>
</operator>
</list>
</operator>
</process>
</operator>
</process>
Hope this helps
<input/>
<output/>
<macros/>
</context>
</operator>
</list>
</operator>
</list>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</operator>
</process>
</operator>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</operator>
</process>
</operator>
</list>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</operator>
</process>
</operator>
</operator>
</operator>
</list>
</operator>
</list>
</operator>
</list>
</operator>
</process>
</operator>
</process>
Hope this helps
Scott
