I am having problem in installation of rapidminer studio in ubuntu 18.04
I have less concept about java, but still i have install as per the instruction. but while running the .sh file it is showing error given below screenshot can anyone help me out.
api@api-HP:~/Downloads/rapidminer-studio-9.2.1/rapidminer-studio$ ./RapidMiner-Studio.sh
RAPIDMINER_HOME is not set. Trying the directory '/home/api/Downloads/rapidminer-studio-9.2.1/rapidminer-studio'...
Exception in thread "main" java.lang.NoClassDefFoundError: javax/xml/bind/DatatypeConverter
at com.rapidminer.license.verification.JarVerifier.verify(JarVerifier.java:130)
at com.rapidminer.launcher.GUILauncher.main(GUILauncher.java:286)
Caused by: java.lang.ClassNotFoundException: javax.xml.bind.DatatypeConverter
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:583)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
... 2 more
api@api-HP:
... 2 more
api@api-HP:
1 - 5 of
51
Hi @MDeb ,
which vesrion of Java are you using? It seems like the one you use is not compatible.
Best,
Martin
@MDeb yes that is certainly your problem. RapidMiner must use JDK 8.x
Hi,
depending on your other requirements, it might make sense to set up java alternatives to easily switch between different Java versions:
Best,
David
David
Hi. Java 8 is required specifically (not even newer versions). Had the same problem (on Ubuntu).
Soln:
1. sudo apt install openjdk-8-jdk openjdk-8-jre # to install required jdk.
2. sudo update-alternatives --config java # to view your jdk versions and choose a comaptible one.
3. select the version with the java8 (1081) in my case. # Use the number in the first column.
4. cd to location of RM. # go to location of RM using terminal.
5. ./RapidMiner-Studio.sh # this will start installation. Be patient.
