Altair RISE
Nominate Yourself Now!
Home
Discussions
Community Q&A
Tableau
[Deleted User]
Hello
@rfuentealba
Look at the screen shot please. I can not use Tableau and also is it possible to use Tableau for visualize the result of our process instead of plot view?
Thank you
AI Studio
Tableau
Accepted answers
All comments
[Deleted User]
https://rapidminer.com/partner/tableau-software/
https://rapidminer.com/resource/better-together-minimizing-machine-failure-rapidminer-tableau/
Most of the time when I search any thing some links like these two links do not work
please help me to solve them.
regards
mbs
sgenzer
hello
@mbs
this is the link you want
https://docs.rapidminer.com/latest/studio/how-to/data-export/tableau.html
Scott
[Deleted User]
@sgenzer
thank you for your answer but please help me to solve the problem which I show that on the previous screen shot
varunm1
Hello
@mbs
Did you follow the exact steps mentioned in the URL link provided by
@sgenzer
during the installation of this extension?
These steps are really important and should be done in a sequence as mentioned in the URL. There might be some installation issue that is throwing this error.
Regards,
Varun
[Deleted User]
@varunm1
I will check it again.
thank you
[Deleted User]
Hi
Is it possible to use Tableau for visualize the result of our process instead of plot view?
Thank you
varunm1
Hello
@mbs
You need to do it with predictions from your model. You can go through the below video for a clear understanding of how both RM and Tableau are used.
Hope this helps.
Thanks,
Varun
[Deleted User]
@varunm1
Thank you very much for the link but
unfortunately it doesnt work
varunm1
Hello
@mbs
Are you asking, if you could visualize the model performances like accuracy, AUC, ROC Curve, etc directly in Tableau?
[Deleted User]
hello
yes.exactly
so how is it possible?
thank you for your help
varunm1
Got it. I don't think you can directly see the results like AUC, ROC curves in Tableau as it takes example set (Data).
@M_Martin
any suggestions.
[Deleted User]
@varunm1
some times the result of plot view is not that much clear so I think if we can show the result of our process in Tableau it is more clear and also more useful
regards
mbs
[Deleted User]
Hello
What is your idea about showing result of our process with Tableau?
Is it possible?
Thanks
varunm1
I dont think you can do that directly, you need to download predictions and then create visualizations based on your need.
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
Groups
