🎉Community Raffle - Win $25
Join and Win
Parameter option missing
User: "Gauthamk"
New Altair Community Member
Updated by Jocelyn
Hi
Relatively new to rapidminer.Today in rapidminer studio I am unable to see the parameter section.i have attached an earlier screenshot where the parameter section was appearing on right hand side of screen .please check and revert
1 - 2 of 21
    User: "sgenzer"
    Altair Employee
    hi @Gauthamk that error message says that you've exceeded your computer's resources. Either sample down the data set or acquire more resources.
    Scott
    User: "varunm1"
    Hello @Gauthamk
    You can enable parameters window in View --> Show Panel --> Parameter present on the menu bar. Also, as scott mentioned above you need downsample or select subset of data for your machine to run the process.
    Thanks
    Varun
