Not getting an output after running some process on Server
Hello,
After i run some process on Server (making some modification on a dataset and then save it on the server Repository using the Store Operator), I waited for long hours and not getting any output.
What could be the problem or the mistake i made ?
Can we see the progress of the process execution from the RM Studio ?
1 - 5 of
51
Hi,
did you check on the Executions tab at the server web view if the process finished correctly (see screenshot below)?
A typical error when switching a process from Studio to Server is that the paths to files and other processes are not changed to a relative path and so can't be resolved in the Server context.
Just copy the address in a browser (e.g., http://192.168.0.1:8080/) and then log in with the same credentials you enter in Studio.
Hi @Zlatan95 ,
the server you are referencing is an internal server which is only to be used by RapidMiner Employees and our business partners. It suprises me a bit that you have access to it?
We did some changes on the server recently. Please consult your Partner manager for the changes.
Best,
Martin
1 - 1 of
11
Hi @Zlatan95 ,
Best,
Martin
