Python Scripting Error
User: "ZAM"
New Altair Community Member
Updated by Jocelyn
Hello
I am getting the following error when I test my python scripting binaries and when I try and use the Execute Python block, any help would be appreciated.
  • Exception: java.nio.file.InvalidPathException
  • Message: Illegal char <"> at index 0: "C:\Program Files\Python37\python.exe"
  • Stack trace:
  • sun.nio.fs.WindowsPathParser.normalize(WindowsPathParser.java:182)
  • sun.nio.fs.WindowsPathParser.parse(WindowsPathParser.java:153)
  • sun.nio.fs.WindowsPathParser.parse(WindowsPathParser.java:77)
  • sun.nio.fs.WindowsPath.parse(WindowsPath.java:94)
  • sun.nio.fs.WindowsFileSystem.getPath(WindowsFileSystem.java:255)
  • java.nio.file.Paths.get(Paths.java:84)
  • com.rapidminer.extension.pythonscripting.operator.scripting.python.PythonSetupTester.quotePath(PythonSetupTester.java:271)
  • com.rapidminer.extension.pythonscripting.operator.scripting.python.PythonSetupTester.getFullPathForPythonBinary(PythonSetupTester.java:766)
  • com.rapidminer.extension.pythonscripting.PluginInitPythonScripting.getDefaultPythonBinary(PluginInitPythonScripting.java:368)
  • com.rapidminer.extension.pythonscripting.PluginInitPythonScripting$3.informParameterSaved(PluginInitPythonScripting.java:313)
  • com.rapidminer.tools.ParameterService.informListenerOfSave(ParameterService.java:492)
  • com.rapidminer.tools.ParameterService.saveParameters(ParameterService.java:389)
  • com.rapidminer.extension.pythonscripting.operator.scripting.python.PythonSetupTester.saveList(PythonSetupTester.java:454)
  • com.rapidminer.extension.pythonscripting.operator.scripting.python.PythonSetupTester.forceRefreshPythonBinaries(PythonSetupTester.java:753)
  • com.rapidminer.extension.pythonscripting.operator.scripting.python.PythonSetupTester.listPythonBinaries(PythonSetupTester.java:494)
  • com.rapidminer.extension.pythonscripting.operator.scripting.python.PythonSetupTester.refreshPythonBinariesCache(PythonSetupTester.java:216)
  • com.rapidminer.extension.pythonscripting.parameter.PythonBinariesSuggestionProvider.runRefreshOperation(PythonBinariesSuggestionProvider.java:40)
  • com.rapidminer.extension.pythonscripting.parameter.AbstractEnvironmentSuggestionProvider$RefreshAction$1.run(AbstractEnvironmentSuggestionProvider.java:75)
  • com.rapidminer.gui.tools.ProgressThread$3.run(ProgressThread.java:561)
  • java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
  • java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
  • java.lang.Thread.run(Thread.java:748)
Thanks.
ZAM
1 - 5 of 51
    User: "hughesfleming68"
    Updated by hughesfleming68
    • Exception: java.nio.file.InvalidPathException. Hello Zam, does your Python installation pass the test in Settings-> Preferences-> Python scripting? This looks like a path problem. Most problems come from paths or not pointing to a correct Python environment.
    User: "IngoRM"
    In particular it looks like the path contains a quote symbol (") which seems to be the problem?  I would try without them...
    User: "varunm1"
    Accepted Answer
    I saw this earlier with @Selim The issue is with spaces in path names. I recommend you install Anaconda with a new environment dedicated to rapidminer that have Python 3.5. This solved a similar error.
    User: "ZAM"
    OP
    @IngoRM There is no (") in the path i double checked it, and tried Python 3.7, 3.6, 3.5.
    all of them not working for the Python Scripting Block
    User: "ZAM"
    OP
    @varunm1 i double checked the path name, there is no spaces in the name.
    However i created a new Environment in Anaconda Dedicated to RapidMiner with 3.5 Python and its working now.
    Thanks.
