Hi people,
How can I after I've split my dataset join them together again in the same order as before?
Below is an example, I just want the ID to go from 1 to 150 again in a chronological order. But just sorting the ID doesn't work.
Also, how can I change the order of attributes in the results?
<pre class="CodeBlock"><code><?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve Iris" width="90" x="45" y="34"><br> <parameter key="repository_entry" value="//Samples/data/Iris"/><br> </operator><br> <operator activated="true" class="split_data" compatibility="9.2.001" expanded="true" height="103" name="Split Data" width="90" x="179" y="34"><br> <enumeration key="partitions"><br> <parameter key="ratio" value="0.66"/><br> <parameter key="ratio" value="0.34"/><br> </enumeration><br> <parameter key="sampling_type" value="automatic"/><br> <parameter key="use_local_random_seed" value="false"/><br> <parameter key="local_random_seed" value="1992"/><br> </operator><br> <operator activated="true" class="union" compatibility="9.2.001" expanded="true" height="82" name="Union" width="90" x="313" y="34"/><br> <connect from_op="Retrieve Iris" from_port="output" to_op="Split Data" to_port="example set"/><br> <connect from_op="Split Data" from_port="partition 1" to_op="Union" to_port="example set 1"/><br> <connect from_op="Split Data" from_port="partition 2" to_op="Union" to_port="example set 2"/><br> <connect from_op="Union" from_port="union" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process>
Thanks
-Prentice
