Altair RISE
Nominate Yourself Now!
Losing contact faces after deleting solid mesh
User: "Yigit Yazicioglu"
New Altair Community Member
Updated by Yigit Yazicioglu
Hi
When I create a face from solid and delete solid element to update the mesh, hypermesh (version 13 to 19th) had always kept the contact surfaces (groups) I generated before.
With version 2022 , when  I take the face and delete solid elements,  all segments (new name for group) are deleted automaticaly. It is very annoying while for a simple update in the mesh, I need to create all contact surfaces again.
Is there any work around for this issue? I dont have access anymore to version 19, if I had I would not update to v21.
1 - 4 of 41
    User: "Ben Buchanan"
    Altair Employee
    Updated by Ben Buchanan
    I think the below option is what you are looking for:
    OP
    no I already tried this,  generate over a solid mesh a surface , then take element face of solid and delete solid element. The concat surface elements will be deleted automaticaly.
    User: "Michael Herve"
    Altair Employee
    Updated by Michael Herve
    Hello
    Yigit Yazicioglu,
    the preference "Allow 2D-3D set segment re-parenting" just below the one suggested by Ben should take care of re-assigning contact surface to shell if you delete solid elements, and vice versa. Did you try it?
    Best Regaerds,
    Michael
    OP
    thanks for your reply. It seems this is the solution but I dont have the same screen you have in preferences.
    How can I open the settings you showed in the picture?
