Hi, i want to know if indexing line and column is possible
nic__o
nic__o New Altair Community Member
edited November 2024 in Community Q&A
Hi, i want to know if  indexing line and column is possible, i want to peak one specific cell of an Excel tab, like [i][j], i tried a lot of operator wihout sucess...
I will really appreciate your answers,
Thank you :)
Welcome!
Best Answer
Answers
  • lionelderkrikor
    lionelderkrikor New Altair Community Member
    Hi @nic__o ,
    You can use Extract Macro operator with  :
     - macro type = data_value (the you choose the example index and the attribute name)
    Regards,
    Lionel
  • nic__o
    Thank's you Lionel its working, but is there a dynamic way to do it ? I mean, for example if I want to pick the last element of a column for any files in entry, is this could be possible ?
    Best regards,
  • MartinLiebig
    MartinLiebig
    Altair Employee
    Hi,
    i think you can btw use -1  as example index to get the last item.
    Best,
    Martin
  • lionelderkrikor
    Hi @mschmitz,
    I must admit that it is a more elegant solution...
    I'm a too complicated boy... :)
    Regards,
    Lionel
Welcome!
Welcome!
