"Details on Vector Linear Regression"
castmonkeys
castmonkeys New Altair Community Member
edited November 2024 in Community Q&A
Hi
I'm doing a very simple regression with RapidMiner. I have tried several regression-models, but the 'Vector Linear Regression' outperforms all of them significantly. So I am now wondering why. I have looked up the docs on https://docs.rapidminer.com/latest/studio/operators/modeling/predictive/functions/vector_linear_regr , but I don't really understand the idea. Even on Google I coulndt find any valuable information about a 'Vector Linear Regression'. So can you share some details on how this algorithm works? I would be interested in a bit more detailed info, e.g. pseudo-code...
BR
Alex
Welcome!
Best Answer
Answers
  • castmonkeys
    edited March 2019
    Hi @SGolbert
    Thanks for the response!
    I am talking about a Vector Linear Regression, sry for the confusion in the title. (I corrected it)
    Okay so now I get the idea of a Vector Linear Regression. But what I still don't get is why it performs much better than a simple Linear Regression, although there's only ONE label in my  dataset.
    BR
    Alex
  • SGolbert
    SGolbert New Altair Community Member
    Hi Alex,
    it should be the same, but the Linear Regression operator does have feature selection and elimination of covariables. You can try disabling these options and comparing once again.
    Regards,
    Sebastian
  • varunm1
    varunm1 New Altair Community Member
    edited March 2019
    Hello
    Ignore this comment as I compared Simple linear regression and Support vector regression. The reason it is performing better is it is more flexible compared to a linear regression algorithm. It takes non-linearity in the distribution of data and overfitting while building model which linear regression does not.
  • SGolbert
    edited March 2019
    I didn't find a reference to the non-linearity part (are you refering to SVM?). I ran a sample process comparing Vector Linear Regression with Linear Regression without feature selection and covariable elimination, and I obtain the same predictions:
    Spoiler
    <?xml version="1.0" encoding="UTF-8"?><process version="9.2.000">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process" origin="GENERATED_TUTORIAL">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="2001"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <process expanded="true">
          <operator activated="true" class="retrieve" compatibility="9.2.000" expanded="true" height="68" name="Polynomial" origin="GENERATED_TUTORIAL" width="90" x="45" y="187">
            <parameter key="repository_entry" value="//Samples/data/Polynomial"/>
          </operator>
          <operator activated="true" class="split_data" compatibility="9.2.000" expanded="true" height="103" name="Split Data" origin="GENERATED_TUTORIAL" width="90" x="112" y="340">
            <enumeration key="partitions">
              <parameter key="ratio" value="0.5"/>
            </enumeration>
            <parameter key="sampling_type" value="automatic"/>
            <parameter key="use_local_random_seed" value="false"/>
            <parameter key="local_random_seed" value="1992"/>
          </operator>
          <operator activated="true" class="multiply" compatibility="9.2.000" expanded="true" height="103" name="Multiply" width="90" x="346" y="263"/>
          <operator activated="true" class="vector_linear_regression" compatibility="9.2.000" expanded="true" height="82" name="Vector Linear Regression" origin="GENERATED_TUTORIAL" width="90" x="581" y="187">
            <parameter key="use_bias" value="true"/>
            <parameter key="ridge" value="1.0E-8"/>
          </operator>
          <operator activated="true" class="linear_regression" compatibility="9.2.000" expanded="true" height="103" name="Linear Regression" width="90" x="581" y="493">
            <parameter key="feature_selection" value="none"/>
            <parameter key="alpha" value="0.05"/>
            <parameter key="max_iterations" value="10"/>
            <parameter key="forward_alpha" value="0.05"/>
            <parameter key="backward_alpha" value="0.05"/>
            <parameter key="eliminate_colinear_features" value="false"/>
            <parameter key="min_tolerance" value="0.05"/>
          </operator>
          <operator activated="true" class="multiply" compatibility="9.2.000" expanded="true" height="103" name="Multiply (2)" width="90" x="246" y="493"/>
          <operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model (2)" origin="GENERATED_TUTORIAL" width="90" x="715" y="646">
            <parameter key="create_view" value="false"/>
          </operator>
          <operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model" origin="GENERATED_TUTORIAL" width="90" x="715" y="232">
          </operator>
          <connect from_op="Polynomial" from_port="output" to_op="Split Data" to_port="example set"/>
          <connect from_op="Split Data" from_port="partition 1" to_op="Multiply" to_port="input"/>
          <connect from_op="Split Data" from_port="partition 2" to_op="Multiply (2)" to_port="input"/>
          <connect from_op="Multiply" from_port="output 1" to_op="Vector Linear Regression" to_port="training set"/>
          <connect from_op="Multiply" from_port="output 2" to_op="Linear Regression" to_port="training set"/>
          <connect from_op="Vector Linear Regression" from_port="model" to_op="Apply Model" to_port="model"/>
          <connect from_op="Linear Regression" from_port="model" to_op="Apply Model (2)" to_port="model"/>
          <connect from_op="Multiply (2)" from_port="output 1" to_op="Apply Model" to_port="unlabelled data"/>
          <connect from_op="Multiply (2)" from_port="output 2" to_op="Apply Model (2)" to_port="unlabelled data"/>
          <connect from_op="Apply Model (2)" from_port="labelled data" to_port="result 2"/>
          <connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/>
          <portSpacing port="sink_result 1" spacing="90"/>
          <portSpacing port="sink_result 3" spacing="0"/>
        </process>
      </operator>
    </process>
    Regards
    Sebastian
  • varunm1
    Hi @SGolbert
    I might be confused. Isn't linear vector regression similar to Support vector regression (SVR) with a linear kernel? Thanks for pointing out
  • SGolbert
    they are not the same, although pointing the difference is not as straightforward as I thought. To begin with, Vector Linear Regression on one label is just ordinary linear regression. The question is then what is the difference between SVR and linear regression.
    I've found this discussion on ResearchGate:
    This exceeds my knowledge of SVR, but it is clear that the cost function is different. Then factors just as sparcity and presence of outliers would dictate which of the two is better for a given problem. Maybe @IngoRM and @mschmitz can provide further insights.
    Regards,
    Sebastian
  • varunm1
    Thanks @SGolbert for clarifying.
  • IngoRM
    IngoRM New Altair Community Member
    The title is a bit confusing still indeed :-) and those are different things.  But Sebastian is right on his interpretation as far as I can see...
    Cheers,
    Ingo
Welcome!
Welcome!
