Enabling SSL in RM Server
Hi RMers,
I've been trying to enable SSL access on the port 8443 again, which I have used with a lot of effort with RM 8.2 before. Unfortunately, I don't have the standalone.xml file that used to work.
I've been following the guide
which at least has an error on the line
openssl pkcs12 -export -out certificate.pfx -inkey privateKey.key -in certificate.crt -certfile chain.crt -name "pkcs12alias"
The
-certfile chain.crt
is not needed.Then, I modified the standalone file to enable the HTTPS part, the server starts but when I try to access it, the following happens:
I have tried providing the full path to the certificate.keystore file and including the
cipher-suite = ...
part with no luck.
The server works normally with HTTP (port 8080).
I have wasted a couple of hours with this already, I would appreciate some help! The feeling of deja vu is the worst part, as exactly the same had happened with the 8.2 server, and these things are so janky and undocumented that unless either the configutation or the documentation is improved, it will continue to happen.
Regards,
Sebastian
