Execute R: Date Missing in Output
Hi,
In my process I have have two operators. the first is read.excel and the other is Execute R. In the latter a script fills NAs in time series (daily). All good with that and when I test the script in Rstudio everything seems to be in place. Though all dates in the output of the operator are missing "?".
Well... in past similar situations that I came across already, after reading some posts here, I was able to proceed by transforming date to character and then in R I would use nominal to date. Which is the solution given in this old thread: https://community.rapidminer.com/discussion/41481/why-date-data-is-missing-after-output-from-execute-r.
If the script works in Rstudio I guess that the issue is just "coming back" to Rapidminer, but what I don't get is why transforming date to character in R is not a solution.
Your help is much appreciated because this is nerve-racking
RM process file and data source example enclosed.
Thanks,
Pedro
Thanks,
Pedro
1 - 5 of
51
Hi Pedro,
let me see if I understood correctly. The problem is that in the output of the Execute R operator, the dates columns are missing?
If you are already transforming to character in R, my guess is that the input dates are not being passed correctly to R. My suggestion is to read the excel files directly in R, RapidMiner can pass the file name if necessary.
Another option is to do the time series processing in RapidMiner, which can be a time saver in the long run.
Regards,
Sebastian
Hi,
@SGolbert exactly.
What is really confusing me is that in Rstudio, after running the script I get a data frame (pic enclosed). I guess that the problem doesn't have to do with importing to R.
I have already tried put date format as yyyy-mm-dd in Rapidminer,but in the end when output of Execute R is always a date column filled with "?".
@hughesfleming68:Already try to transform before in nominal.
Still getting the "?" dates
Regards,
Pedro
@SGolbert exactly.
Regards,
Pedro
@hughesfleming68 thanks a lot. That works.
In the meanwhile I was able to find a workaround: I just transformed, in R, date column to character and add a random piece of string with "//" as separator. Then, "back" in RM, I used "split" and "nominal to date". This allowed me to proceed work.
But of course... Your solution is way more elegant and I'll stick to it.
Again thanks a lot.
Regards,
Pedro
Again thanks a lot.
Regards,
Pedro
1 - 1 of
11
This is a Posix date problem. dateoutput<-as.POSIXct(date, tz = "")
In your code:-
ds2<-ds2%>%
fill(grw,block)
ds2$day<-as.POSIXct(ds2$day)
return(as.data.frame(ds2))
or just import the process I uploaded.
regards,
Alex
regards,
Alex
