🎉Community Raffle - Win $25
Join and Win
Uniformity Index
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
Kindly let us know how to calculate the flow uniformity through a given section/plane.
1 - 8 of 81
    Altair Employee
    OP
    Hi Dinesh,
    Please find attached script for computation of Uniformity Index (UI) in Acufieldview.
    In the script, you can edit the below according to your problem:
    Using this script you can compute the UI value for the boundary surfaces.
    You can execute this script in Acufieldview,  (Tools --> Execute FVX File)
    As soon as you execute the script, the UI value would be printed on the screen.
    Please let me know if you have any questions.
    Regards,
    Kamlesh
    Altair Employee
    OP
    Hi Kamlesh,
    Invalid scalar function error.
    Let me know to rectify the error.
    Altair Employee
    OP
    Hi Dinesh,
    if you are using latest version ie 2017 no need to use script.
    UI id directly available as a output in acuProbe under Surface Statisctics. as shown in below image.
    Regards
    Ravi
    Altair Employee
    OP
    Thanks Ravi!!!!
    User: "Ian P"
    Altair Community Member
    Updated by Ian P
    @Altair Forum User @acupro  are there any updates you can provide as to how to calculate uniformity index in HyperWorks CFD 2021.1 ?? Is there a similar output for volume-averaged uniformity index?
    User: "acupro"
    Altair Employee
    Updated by acupro
    The Plot utility from the Solution ribbon has essentially the same functionality for surface results uniformity - through surface statistics
    I'm not aware of anything built-in to handle volume uniformity.  What is your use-case, and what do you want to calculate?
    User: "Ian P"
    Updated by Ian P
    Thanks. Ended up stumbling across this. Grouping surfaces via setting up a monitor prior to solving was helpful too.
    I'm simulating flow through porous media and want to look at uniformity of a given velocity component. Volume uniformity has been helpful for this type of application in other commercial packages in the past. The definition used for a component "v" for all cells "c" in the volume "V" was:
    I don't have much experience with AcuSolve, etc. prior to HW CFD; would an external script be needed to implement the above metric?
    User: "acupro"
    Altair Employee
    Updated by acupro
    Indeed, the collections for Surface Output are quite handy in HyperWorks CFD, as the collections can be independent of other collections.
    I'm told you may be able to do something approximate for volume uniformity with a python script accessing the solution database directly - but that is not my area of knowledge...
