"Performance =
I have used the optimize paramater on knn on a training and validation dataset to create a model. When I apply this model to new data, a predicted value for the labeled variable is created, however the performance (RMSE, adjusted r^2) is reported as "unknown" for the new data. (I am able to see the performance of the original training model).
Why is this happening? How do I fix it?
I have attached all appropriate files and rmp files
totally logic !
In your score set, you don't supply a "true value" for your label.
So it's impossible for RapidMiner to compare the predictions to the true labels to in fine calculate a performance...
I hope it is clear,
Regards,
Lionel
