Calling Server webservice from a form on a webpage
Hi Community,
I need to create a webpage that has a form with one entry field. The end user would enter a value in the form and hit a web button on the page. Then from there it would call a Server webservice using the value as URL Parameter, pass it, score, and send the results back to the web page.
Has anyone in the Community done something like this? Is there a sample you can share. My thought is that it will require javascript and possible a response back from the Server as XML or JSON. Looking for any help or a point in the right direction.
Thanks!
