🎉Community Raffle - Win $25
Join and Win
"Setting Custom Weights From Example Set Table"
User: "dragoljub"
New Altair Community Member
Updated by Jocelyn
Hi Everyone,
I have a table of attribute names and corresponding weights independently computed from outside rapid miner. I need to convert this Example Set into a weights type. I assumed that Data to Weights would do this for me, however it seems that it only creates a weight set from the attributes so that each weight set to 1... what is the purpose of this?
I know there is the weight by user specification but that requires manual setting of each attribute weight. I have 765 attributes and weights that I cannot manually enter.
How Can I generate a weight table for use in rapid miner from my own data?!  ???
Thanks,
-Gagi
