RapidMiner Crashes when Exporting Process using Print/Export Image OR Export Process
Hey guys and gals,
has anyone experienced a similar error? My RapidMiner on MacOS 10.12.6 is crashing whenever I try to export my process using either "Export Process" or "Print/Export Image". This happens regardless of the process, even with one blank module.
Any recommendations?
Best,
Lino
Here's an Excerpt from the Crash Report:
System Integrity Protection: enabled
Crashed Thread: 28 Java: AWT-EventQueue-0
Exception Type: EXC_BAD_ACCESS (SIGABRT)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000008
Exception Note: EXC_CORPSE_NOTIFY
VM Regions Near 0x8:
__TEXT 000000010e95a000-000000010e96c000 [ 72K] r-x/rwx SM=COW /Applications/RapidMiner Studio.app/Contents/PlugIns/jre_1.8.0_XX.jre/Contents/Home/bin/java
Application Specific Information:
abort() called
abort() called
1 - 10 of
101
Hey @sgenzer ,
I just sent you the requested files.
Regarding my choice of OS: Everything works right now, Sierra still gets stability and security patches, so I'm good. Since I am and have been working on finishing my studies (Master's Thesis) and this is my main writing machine, I've learned better than to mess with something I'm depending on while wanting to concentrate on something else.
That said, a clean install of Mojave is on my list for this spring
Best,
Lino
Hey @sgenzer,
sorry, this wasn't clear: RapidMiner still crashes on that operation, I was referring to my machine in general, so "everything works" is probably not the correct choice of words. The problem persists, I can not export my process.
Best regards,
Lino
Lino
Updated by MartinLiebig
Hi @ljorzic ,
in the beta for RM 9.2 (released a few minutes ago) we have a complete new charting engine. Maybe it is better to take this.
Edit: Nevermind, you talked about images of processes...
BR,
MArtin
thx @mschmitz I think (?) we sorted it out. There's a good name that @Marco_Boeck has coined for what is happening here but I will try to keep this conversation clean.
Scott
Scott
New Altair Community Member
Updated by Marco_Boeck
Hi,
Is your Mac having a touchbar? I found some other application crash reports looking almost identical for Macs with a touchbar.
Regards,
Marco
Regards,
Marco
@Marco_Boeck the Java installation was really messed up due to some homebrew installations - we suspect this may be the culprit. Log files show no crash at all - just ends.
Thanks.
Scott
