Altair RISE
Nominate Yourself Now!
Acusolve - Exhaust Manifold Simulation
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello Forum,
I am a student and am learning how to use acusolve, I would like to know how to make a simulation of an exhaust manifold. I want to know what I have to define so I can have inlet conditions that change by time, do I only need to modify boundary conditions?
Thanks,
1 - 12 of 121
    User: "ydigit"
    Altair Employee
    Updated by ydigit
    You would need
    Global
    -  Auto Solution Strategy- Transient.
    - Multiplier Function
    Model-
    - Inflow boundary condition with a multiplier function. This multiplier function defined above
    Altair Employee
    OP
    You would need
    Global
    Model-
    Do you have a tutorial on how to use the multiplier function?
    User: "ydigit"
    Altair Employee
    Updated by ydigit
    This might help you to get started.
    Altair Employee
    OP
    Now I get this error message as I run Acusolve, any tip?
    acuSolve: ---------------------- Begin Time Step ----------------------
    acuSolve: Time-Step=    1 ; timeInc= 1.000000e+010 ; time= 0.000000e+000
    acuSolve: *** ASSERTION in Function <fElm3TwfVelSp>
    acuSolve: *** no convergence
    acuRun: *** ERROR: error occurred executing acuSolve'
    acuRun: Tue Apr 21 09:03:15 2015
    User: "ydigit"
    Altair Employee
    Updated by ydigit
    Could you upload the .ACS file?
    It seems you are using the same time step as for steady state. Time Inc = 100000000?
    If you are running transient, also select a realistic time increment.
    Altair Employee
    OP
    what would be a more realistic time step? (I can not upload the file, the forum says I am not permitted to upload that kind of file)
    Thanks,
    User: "ydigit"
    Altair Employee
    Updated by ydigit
    Time step 0.1 sec might be a good starting point.
    Please upload .inp and .Log file. If necessary, rename the extension to .txt.
    Altair Employee
    OP
    Here it is.
    Altair Employee
    OP
    It does not helped the 0.1 seconds, I still have the same error
    User: "ydigit"
    Altair Employee
    Updated by ydigit
    The problem was the Time  was supposed to be Piecewise Linear.
    With that one change it runs. Input file attached.
    BTW, you would need to makes considerable changes to get useful results. Mesh is too coarse to get any accurate results. Also Nodal Output would be have to be changed to lesser value (e.g. 1 or 10), instead of current default 1000.
    If you have not attended any training, I would recommend to visit an AcuSolve training at the nearest Altair location.
    Altair Employee
    OP
    Thanks,  the Time should be change only in the multiplier function or where else did you put Piecewise Linear
    User: "ydigit"
    Altair Employee
    Updated by ydigit
    Please compare the .INP file I uploaded with the one you uploaded image/emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
    # | Multiplier Function                                                  |
    MULTIPLIER_FUNCTION( 'time' ) {
        type                                = piecewise_linear
        curve_fit_values                    = { 0.0, 900.0;
                                                5.0, 900.0;
                                                7.5, 0.0;
                                                10.0, 0.0;
                                                12.5, 900.0; }
        curve_fit_variable                  = time
        evaluation                          = once_per_time_step
        filter                              = none
