1 - 2 of
21
Bummer...
Seems like it's not working indeed if I use the 'windows user path logic' (which would have been /Documents/Formations_DataScience in your example), while ok if I use the C:\ path logic. I prefer the first one since it makes it equal to my Linux server environment and then I could have kept it simple.
Anyway, happy holidays for you also !
1 - 1 of
11
Hi @kayman,
A priori, you have to set the "absolute path" of your file (including the extension) in the condition value parameter of the Branch operator.
Take a look at this process :
<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="operator_toolbox:create_exampleset" compatibility="1.7.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="85"> <parameter key="generator_type" value="comma_separated_text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="input_csv_text" value="Id,Att1 1,1 2,2 3,3 4,4"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="concurrency:loop_files" compatibility="9.1.000" expanded="true" height="82" name="Loop Files" width="90" x="246" y="85"> <parameter key="directory" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Ambassador_Role"/> <parameter key="filter_type" value="glob"/> <parameter key="filter_by_glob" value="*.docx"/> <parameter key="filter_by_regex" value="*docx"/> <parameter key="recursive" value="false"/> <parameter key="enable_macros" value="false"/> <parameter key="macro_for_file_name" value="file_name"/> <parameter key="macro_for_file_type" value="file_type"/> <parameter key="macro_for_folder_name" value="folder_name"/> <parameter key="reuse_results" value="true"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="branch" compatibility="9.1.000" expanded="true" height="103" name="Branch" width="90" x="313" y="34"> <parameter key="condition_type" value="file_exists"/> <parameter key="condition_value" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Ambassador_Role\Process.docx"/> <parameter key="expression" value=""/> <parameter key="io_object" value="ANOVAMatrix"/> <parameter key="return_inner_output" value="true"/> <process expanded="true"> <operator activated="true" class="generate_attributes" compatibility="9.1.000" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="136"> <list key="function_descriptions"> <parameter key="Att2" value="2*Att1"/> </list> <parameter key="keep_all" value="true"/> </operator> <connect from_port="condition" to_port="input 1"/> <connect from_port="input 1" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="input 2"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> <portSpacing port="sink_input 3" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="generate_attributes" compatibility="9.1.000" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="179" y="85"> <list key="function_descriptions"> <parameter key="Att2" value="0"/> </list> <parameter key="keep_all" value="true"/> </operator> <connect from_port="condition" to_port="input 1"/> <connect from_port="input 1" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_port="input 2"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> <portSpacing port="sink_input 3" spacing="0"/> </process> </operator> <connect from_port="file object" to_op="Branch" to_port="condition"/> <connect from_port="input 1" to_op="Branch" to_port="input 1"/> <connect from_op="Branch" from_port="input 2" to_port="output 1"/> <portSpacing port="source_file object" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Loop Files" to_port="input 1"/> <connect from_op="Loop Files" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
I hope it helps,
Regards and happy holidays,
Lionel
Lionel
Lionel
