"How to test the assumptions of logistic regression in RM?"
New Altair Community Member
Updated by Jocelyn
Hello ! I am getting a bit lost in my analysis and I am stuck between two steps of my methodology. I had a classification problem (churn) with a dataset of 100 variables for 100 000 examples and, after removing attributes with too many missing values and those that were too correlated to others (pairs with a correlation above 75%) or with a too small variance, I have 46 attributes and 80 000 examples in my training set.
However, I'd like to have between 10-15 attributes approximately and to do so, I'm using a backward elimination. This means that I have to already choose a predictive model and for now, I chose either Random Forest or Logistic Regression. My first question would be: which backward elimination model choosing knowing that the results are much different whether I do it with a logistic regression or with Random Forest? Then, I have mainly 2 questions:
1. ASSUMPTIONS BEHIND MODELS
For logistic regression, if I choose this one, I am not sure how to verify the assumptions linked to this model in Rapid Miner:
2. CHOOSING THE MODEL - Blackbox models
Finally, after the backward elimination, how can I choose the best model? I know I can compare their ROC, AUC or accuracy but I also need to take into account whether the hypothesis are verified and whether it's easily interpretable for anyone not familiar with data science. For example, I would like to avoid so-called "blackbox" models such as Neural Nets but would you consider Random Forest as a blackbox model?
Thank you all for your help, I'm getting a bit stressed by my incoming deadline and will appreciate all advices
- I have no idea how to test in Rapid Miner the linearity between the independent variables and the log odds of the dependent variable. I read a bit about Box-Tidwell test but can't find that on RM. Do you have any advices or help to offer?
- Hypothesis of Little or no multicolinearity among the variables: is it problematic as I know some are still correlated above 50%?
1 - 7 of
71
Hi,
Ok, thanks for the reassuring reply! It's for my thesis though and I don't know how much they'll pay attention to that. My jury is not composed of statistical experts, which is nice, but I still fear that using a model that does not allow multicollinearity between variables may look bad. But I guess I'll leave the linearity issue on the side then!
Regarding independency between variables, would you consider a correlation of 50% as breaking the independency? I tried remove all pairs above that threshold.
Thanks again!
Ophélie
Thanks again!
Ophélie
Actually, since I had 90 attributes in the first place, I checked the correlation matrix and for all pairs above 75-80%, I removed one of the 2 attributes, keeping the "best one" (less Missing Values or outliers, checked info gain and did some tests to verify that the AUC was not dropping when removing it). Then, I performed my backward elimination with 46 attributes (it was way too slow otherwise), went to 15 attributes and only then, I removed 2 attributes that had a correlation above 50% with others and the AUC did not drop (it went from 67,7 to 67,6 so I thought it was for the best, now I have 13 attributes). But for me, high correlation was not a good thing... Was I wrong?
Hi @ophelie_vdp
CHOOSING THE MODEL:
You can also explain neural networks. First thing with the dataset (Classification) is to visualize the class distributions. Try to visualize the the dataset using T-SNE in 2 or 3 dimension. This is will give you a better understanding of how your classes are distributed. As all the algorithms doesn't give us best results we can observe and hypothesize based on the distributions. For example: If the classes are plotted as small distributions here and there on the plot, neural networks and deep learning works better. This is because they are able to calculate local minima of each distribution. If the classes are linearly separated then traditional algorithms work better. For subset selection, you can use best subset selection which is computationally expensive but gives the best attributes that are significant for training and testing based on the 2^p model training. This will give you the significant attributes when you use 10 variables or 15 variables similar to step wise selection. Lasso can be used for multicollinearity problem.
Two more performance metrics that needs to be considered are Kappa(inter-rater agreement) and RMSE which gives you the performance based on individual class prediction. Accuracy cannot be good in all cases as it depends on class distribution (class imbalance).
@mschmitz correct me if there is any issue in this.
Thanks,
Varun
CHOOSING THE MODEL:
Thanks,
Varun
Not necessarily wrong, but perhaps I am not understanding really what the question is here. If you are interested in building the best possible model in terms of performance while avoiding overfitting or too many predictors, you should probably look at evolutionary feature selection rather than a backward elimination model, which is still subject to overfitting or getting caught in a local optimum based on the somewhat deterministic path of feature elimination. Ingo wrote a great blog tutorial about how to do this, which is available here: https://rapidminer.com/blog/multi-objective-optimization-feature-selection/
as a data scientist you may not be intersted if your assumptions are valid (it might be good though). You are interested in choosing the model which can optimize your quality measure (e.g. revenue). If a model like a linear regression, which is only valid for linear cases works, than i take it.
BR,
Martin
