Altair RISE
Nominate Yourself Now!
New guy - learning how to clean up and parse a CSV file
User: "WesCo2019"
New Altair Community Member
Updated by Jocelyn
I am new to data analysis and preparing a data set.  I have a CSV file with the time stamp in the following format: "2018/05/14:12:00:00 PM."
What is a recommended way to "parse" the time stamp into Year, date, and time components to make it easier to sort and filter?
Thanks!
1 - 4 of 41
    User: "sgenzer"
    Altair Employee
    Accepted Answer
    hi @WesCo2019 - you're going to want to first put it into a date-time data type:
    As for parsing, I would use "Generate Attributes" to create separate attributes for each piece you want:
    <?xml version="1.0" encoding="UTF-8"?><process version="9.0.003">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.0.003" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Lake Huron" width="90" x="45" y="34">
            <parameter key="repository_entry" value="//Samples/Time Series/data sets/Lake Huron"/>
          </operator>
          <operator activated="true" class="generate_attributes" compatibility="9.0.003" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="34">
            <list key="function_descriptions">
              <parameter key="Year" value="date_get(Date,DATE_UNIT_YEAR)"/>
              <parameter key="Month" value="date_get(Date,DATE_UNIT_MONTH)"/>
              <parameter key="Week" value="date_get(Date,DATE_UNIT_WEEK)"/>
              <parameter key="Day" value="date_get(Date,DATE_UNIT_DAY)"/>
              <parameter key="Hour" value="date_get(Date,DATE_UNIT_HOUR)"/>
            </list>
          </operator>
          <connect from_op="Retrieve Lake Huron" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
          <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
    Hope that helps.
    Scott
    User: "hughesfleming68"
    Updated by hughesfleming68
    You can also define the date-time format in the csv import wizard and save one step. Which I see Scott has already pointed out. I didn't see the first image.
    User: "Telcontar120"
    Or you can use "Date to Numerical" and then specify the date component you want to extract.
    User: "WesCo2019"
    OP
    Thanks to all for the helpful insght
