Filter Tokens by Content (more than one expression)
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="341" width="756">
<operator activated="true" class="read_database" compatibility="5.2.008" expanded="true" height="60" name="Read Database" width="90" x="45" y="75">
<parameter key="connection" value="sqlserver"/>
<parameter key="query" value="SELECT `Bewertung` FROM `training_schnell`"/>
<enumeration key="parameters"/>
</operator>
<operator activated="true" class="nominal_to_text" compatibility="5.2.008" expanded="true" height="76" name="Nominal to Text" width="90" x="179" y="75"/>
<operator activated="true" class="text:process_document_from_data" compatibility="5.2.004" expanded="true" height="76" name="Process Documents from Data" width="90" x="313" y="75">
<parameter key="prunde_below_percent" value="5.0"/>
<parameter key="prune_above_percent" value="100.0"/>
<list key="specify_weights"/>
<process expanded="true" height="345" width="774">
<operator activated="true" class="text:tokenize" compatibility="5.2.004" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30">
<parameter key="mode" value="specify characters"/>
<parameter key="characters" value=".:,:;:!:?:|:"/>
</operator>
<operator activated="true" class="text:filter_by_length" compatibility="5.2.004" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="45" y="120">
<parameter key="max_chars" value="9999"/>
</operator>
<operator activated="true" class="text:filter_stopwords_german" compatibility="5.2.004" expanded="true" height="60" name="Filter Stopwords (German)" width="90" x="45" y="210"/>
<operator activated="true" class="text:stem_german" compatibility="5.2.004" expanded="true" height="60" name="Stem (German)" width="90" x="179" y="30"/>
<operator activated="false" class="text:filter_tokens_by_content" compatibility="5.2.004" expanded="true" height="60" name="Filter Tokens (by Content)" width="90" x="447" y="165">
<parameter key="string" value="schnell "/>
<parameter key="regular_expression" value="(schnell)"/>
</operator>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Filter Stopwords (German)" to_port="document"/>
<connect from_op="Filter Stopwords (German)" from_port="document" to_op="Stem (German)" to_port="document"/>
<connect from_op="Stem (German)" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<operator activated="false" class="text:wordlist_to_data" compatibility="5.2.004" expanded="true" height="76" name="WordList to Data" width="90" x="313" y="210"/>
<operator activated="true" class="filter_examples" compatibility="5.2.008" expanded="true" height="76" name="Filter Examples" width="90" x="514" y="30">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="Bewertung = .*wieder.*|.*lieferung.*|.*schnell.*"/>
</operator>
<operator activated="true" class="write_excel" compatibility="5.2.008" expanded="true" height="76" name="Write Excel" width="90" x="514" y="165">
<parameter key="excel_file" value="C:\Users\MP-TEST\Desktop\Rapid_Test\Klein.xls"/>
</operator>
<connect from_op="Read Database" from_port="output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Write Excel" to_port="input"/>
<connect from_op="Write Excel" from_port="through" to_port="result 1"/>
</process>
</operator>
</process>
I have been following this post and your other post for quite some time, and I get the feeling that it may be a good idea to step one step back, leave the rather complicated text processing aside and get used to the common concepts of RapidMiner and data mining with RapidMiner with the help of our tutorials. That will make it much easier for you to assemble your processes, and debug them if anything does not work. There is also a good book available which is even downloadable for free: search for "Data Mining for the Masses" by Matt North. Here the author explains many concepts of data mining on simple, but realistic examples, starting at a very basic level and advancing to more and more complex topics. Most of the chapters use RapidMiner as the platform for doing the exercises.
If you have any further questions you are of course invited to ask for help here on the forums!
All the best,
Marius
Actually, I have tried Tokens by Content, but actually I couldn't figure out how to specify more than one expression in the corresponding field, I tried search the sample syntax, but no result. :-\
.*dog.*|.*cat.*|.*fish.*would match doghouse, catfish, fish food, and anything else containing one of the words.
Regular expressions are quite complex, and there exist complete books on only this topics. The basic syntax however can be quickly learned from tutorials on the internet.
RapidMiner contains a regular expression dialog, where you can directly test the expressions you entered. It is available in many parameters where you can enter regular expressions, e.g. Select Attributes (with attribute_filter_type = regular_expression). Since the dialog is quite new, not all fields have been ported, so its not yet in Filter Tokens. There are also many free regex testers on the internet.
Happy Mining!
~Marius
The used regular expression is a bit on the greedy side, meaning you can have a lot of results, but not the right ones depending on how your text is structured.
In the given example it will only match the exact case, so if you have for instance Fish (with capital F) , it will not match. it will also capture fishing, hotdog, category and so on, and while that might be useful for some scenarios it can also lead to unexpected results again.
There are ways to improve this, using some of the more advanced yet cool options of regular expressions.
you could use groups to start with, that reduces the wildchards already and makes it more readable and less error prone.
The above becomes then
.*(cat|dog|fish).*
It does exactly the same, it reads as 'take whatever you want (the dot), as many times as you like (the asterix) followed by either cat, dog or fish, and then again followed by whatever as much as you want.
This is what we call a greedy pattern, we don't care of what we get and how much we have. This si typically no problem when dealing with small sentences, but can cost you a lot of memory when you have long content.
so one small improvement already :
.*?(cat|dog|fish).*^
Ok, 2 small changes. The first is the 'hat' (^), which means, begin at the start of the sentence, and the question mark, which means 'end at the first match. So using ^.*? is short for begin at the start, and end as soon as you find the first match. This can save quite some time again with large texts, as the original one will just keep looking for matches untill he is at the end of the sentence.
Now, we still can only match lower case, and while it is good practice to set all of your cases either lower or upper in a text analysis workflow, there are occasions where we need the difference of course. Anyway, to ignore cases we use the i flag as follows :
^.*?(cat|dog|fish).*(?i)So now it will find cat, Cat, CAT, and whatever else. Should that be a requirement of course.
You can combine many flags together, while the i flag means ignore case, the m flag can be used to indicate you can have multiple lines. combining them as below would mean that every sentence, when using line breaks, would get the same treatment.
^.*?(cat|dog|fish).*</code><code>(?im)the order doesn't matter, (?mi) would work exactly the same.
Now, we still have the problem we can get things like category or hotdog in the results, so the final part would be to use the word boundary, so that we are ensured we only get a match when it is exactly the same word. A word boundary can be anything like a comma, a dot, a space, end or beginning of sentence etc. Luckily there is a little helper again, so the below will give you an exact match, stop at the first match, looking at every line you have.
(?im)^.*?\b(cat|dog|fish)\b.*</code><code>
As an alternative you could also use the s flag when you have a lot of line breaks, and this will ignore all linebreaks and treat your text as one single line.
^.*?\b(cat|dog|fish)\b.*</code><code>(?is)FINAL EDIT : it seems the code block screws the content a bit up, all of the symbols used need to be in one single line.
Regex is probably not going to work here if that is what you want to achieve.
