Which function to use to produce performance results set using evolutionary optimization and neural
TeeH
TeeH New Altair Community Member
edited November 2024 in Community Q&A
Which functions to use to produce performance example set, when optimizing regression model of neural net, nested into sliding window validation using evolutionary optimization, i tried performance, regression performance function, almost all of them, but the model cant produce performance example set to be able to plot the results.
Answers
  • Telcontar120
    Telcontar120 New Altair Community Member
    Performance(Regression) should be the correct one if you have a numerical label.  But it is not feasible to diagnose your problem from your description.  You should attach your xml so we can inspect the process itself.  Also, did you review the tutorial process for the Optimize operator, that indicates the way that the operators need to be wired in order to produce the correct output.
Welcome!
Welcome!
