filter Numerical Label by top 75% quartile
msacs09
msacs09 New Altair Community Member
edited November 2024 in Community Q&A
How do i filter a numerical label to only 75% quartile, such that i convert a numerical label to binomial (i.e) either in 75% or not?
Welcome!
Answers
  • lionelderkrikor
    lionelderkrikor New Altair Community Member
    edited December 2018
    HI @msacs09,
    It's far fetched, but does this process answer to your need ?
    Edit : You need RapidMiner 9.1 (beta) to execute this process.
    Spoiler
    <?xml version="1.0" encoding="UTF-8"?><process version="9.1.000-BETA2">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.1.000-BETA2" expanded="true" name="Process">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="2001"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <process expanded="true">
          <operator activated="true" class="retrieve" compatibility="9.1.000-BETA2" expanded="true" height="68" name="Retrieve Golf" width="90" x="45" y="85">
            <parameter key="repository_entry" value="//Samples/data/Golf"/>
          </operator>
          <operator activated="true" class="select_attributes" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="85">
            <parameter key="attribute_filter_type" value="single"/>
            <parameter key="attribute" value="Temperature"/>
            <parameter key="attributes" value=""/>
            <parameter key="use_except_expression" value="false"/>
            <parameter key="value_type" value="attribute_value"/>
            <parameter key="use_value_type_exception" value="false"/>
            <parameter key="except_value_type" value="time"/>
            <parameter key="block_type" value="attribute_block"/>
            <parameter key="use_block_type_exception" value="false"/>
            <parameter key="except_block_type" value="value_matrix_row_start"/>
            <parameter key="invert_selection" value="false"/>
            <parameter key="include_special_attributes" value="false"/>
          </operator>
          <operator activated="true" class="aggregate" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Aggregate" width="90" x="313" y="85">
            <parameter key="use_default_aggregation" value="false"/>
            <parameter key="attribute_filter_type" value="all"/>
            <parameter key="attribute" value=""/>
            <parameter key="default_aggregation_function" value="average"/>
            <list key="aggregation_attributes">
              <parameter key="Temperature" value="percentile (75)"/>
            </list>
            <parameter key="group_by_attributes" value=""/>
            <parameter key="count_all_combinations" value="false"/>
            <parameter key="only_distinct" value="false"/>
            <parameter key="ignore_missings" value="true"/>
          </operator>
          <operator activated="true" class="generate_id" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Generate ID (2)" width="90" x="447" y="136">
            <parameter key="create_nominal_ids" value="false"/>
            <parameter key="offset" value="0"/>
          </operator>
          <operator activated="true" class="generate_id" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Generate ID" width="90" x="447" y="34">
          </operator>
          <operator activated="true" class="union" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Union" width="90" x="581" y="85"/>
          <operator activated="true" class="replace_missing_values" compatibility="9.1.000-BETA2" expanded="true" height="103" name="Replace Missing Values" width="90" x="719" y="85">
            <parameter key="return_preprocessing_model" value="false"/>
            <parameter key="create_view" value="false"/>
            <parameter key="attribute" value="percentile (75)(Temperature)"/>
            <parameter key="default" value="average"/>
            <list key="columns">
              <parameter key="percentile (75)(Temperature)" value="average"/>
            </list>
          </operator>
          <operator activated="true" class="filter_example_range" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Filter Example Range" width="90" x="853" y="85">
            <parameter key="first_example" value="1"/>
            <parameter key="last_example" value="1"/>
            <parameter key="invert_filter" value="true"/>
          </operator>
          <operator activated="true" class="generate_attributes" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Generate Attributes" width="90" x="987" y="85">
            <list key="function_descriptions">
              <parameter key="temperature_binominal" value="if(Temperature&gt;=[percentile (75)(Temperature)],1,0)"/>
            </list>
            <parameter key="keep_all" value="true"/>
          </operator>
          <connect from_op="Retrieve Golf" from_port="output" to_op="Select Attributes" to_port="example set input"/>
          <connect from_op="Select Attributes" from_port="example set output" to_op="Aggregate" to_port="example set input"/>
          <connect from_op="Aggregate" from_port="example set output" to_op="Generate ID" to_port="example set input"/>
          <connect from_op="Aggregate" from_port="original" to_op="Generate ID (2)" to_port="example set input"/>
          <connect from_op="Generate ID (2)" from_port="example set output" to_op="Union" to_port="example set 2"/>
          <connect from_op="Generate ID" from_port="example set output" to_op="Union" to_port="example set 1"/>
          <connect from_op="Union" from_port="union" to_op="Replace Missing Values" to_port="example set input"/>
          <connect from_op="Replace Missing Values" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/>
          <connect from_op="Filter Example Range" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
          <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
    Regards,
    Lionel
  • Telcontar120
    Telcontar120 New Altair Community Member
    There is an operator called Winsorize which is in the free Finance and Economics extension which basically does this.  Actually it lets you cap values at the 75th percentile (or whatever percentile you select), and then you could use the standard Numerical to Binominal operator after that to convert that to a 0/1 flag based on the value.
  • msacs09
    Thank you all
Welcome!
Welcome!
