<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000-BETA2"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.1.000-BETA2" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.1.000-BETA2" expanded="true" height="68" name="Retrieve Golf" width="90" x="45" y="85"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="select_attributes" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Temperature"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="aggregate" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Aggregate" width="90" x="313" y="85"> <parameter key="use_default_aggregation" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_aggregation_function" value="average"/> <list key="aggregation_attributes"> <parameter key="Temperature" value="percentile (75)"/> </list> <parameter key="group_by_attributes" value=""/> <parameter key="count_all_combinations" value="false"/> <parameter key="only_distinct" value="false"/> <parameter key="ignore_missings" value="true"/> </operator> <operator activated="true" class="generate_id" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Generate ID (2)" width="90" x="447" y="136"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="generate_id" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Generate ID" width="90" x="447" y="34"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="union" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Union" width="90" x="581" y="85"/> <operator activated="true" class="replace_missing_values" compatibility="9.1.000-BETA2" expanded="true" height="103" name="Replace Missing Values" width="90" x="719" y="85"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="create_view" value="false"/> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="percentile (75)(Temperature)"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default" value="average"/> <list key="columns"> <parameter key="percentile (75)(Temperature)" value="average"/> </list> </operator> <operator activated="true" class="filter_example_range" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Filter Example Range" width="90" x="853" y="85"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="1"/> <parameter key="invert_filter" value="true"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Generate Attributes" width="90" x="987" y="85"> <list key="function_descriptions"> <parameter key="temperature_binominal" value="if(Temperature>=[percentile (75)(Temperature)],1,0)"/> </list> <parameter key="keep_all" value="true"/> </operator> <connect from_op="Retrieve Golf" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Aggregate" from_port="original" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Union" to_port="example set 2"/> <connect from_op="Generate ID" from_port="example set output" to_op="Union" to_port="example set 1"/> <connect from_op="Union" from_port="union" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
