I Actually have the rapidlab software, by the moment I have a problem in the simulation step. When I click on the Simulate button the next warning appears "Simulaiton failed: The average step size was not properly calculated The step size is 0 s or 0ms, respectively" Has anybody seen this problem?
Where did you find that?! That product has been discontinued for about 8 years
You may want to look into the Auto Model component however, which is up to date and there is also model simulation available.
Regards,
Marco
