CSV with uncommon header can't be processed correctly
New Altair Community Member
Updated by Jocelyn
Hi all,
I am using the "Read CSV" operator to read a CSV-file with multiple lines. The problem is that the first few lines are all technical information that are not in a valid CSV format, so I define them as Comment. But then, only column one of the last row with the values is read.
Is this a common error? I think it might be caused because there are more lines, with different amount of columns, but because I define these as Comment I don't understand why it doesn't work.
This is my operator for "TEST_Jette.csv"
Thanks in advance
Pello
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.1.003" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_csv" compatibility="8.1.003" expanded="true" height="68" name="Read CSV" width="90" x="179" y="34">
<parameter key="csv_file" value="/Users/pello/Downloads/TEST_Jette.csv"/>
<parameter key="skip_comments" value="true"/>
<parameter key="parse_numbers" value="false"/>
<parameter key="decimal_character" value=","/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Comment"/>
<parameter key="1" value="Comment"/>
<parameter key="2" value="Comment"/>
<parameter key="3" value="Comment"/>
<parameter key="4" value="Comment"/>
<parameter key="5" value="Comment"/>
<parameter key="6" value="Comment"/>
<parameter key="7" value="Comment"/>
<parameter key="8" value="Comment"/>
<parameter key="9" value="Comment"/>
<parameter key="10" value="Comment"/>
<parameter key="11" value="Comment"/>
<parameter key="12" value="Comment"/>
<parameter key="13" value="Comment"/>
<parameter key="14" value="Comment"/>
<parameter key="15" value="Comment"/>
<parameter key="16" value="Comment"/>
<parameter key="17" value="Name"/>
</list>
<parameter key="encoding" value="UTF-8"/>
<parameter key="read_all_values_as_polynominal" value="true"/>
<list key="data_set_meta_data_information">
<parameter key="0" value="timestamp.true.polynominal.attribute"/>
</list>
</operator>
<connect from_op="Read CSV" from_port="output" to_port="result 1"/>
</process>
</operator>
</process>
Thanks in advance
Pello
1 - 4 of
41
yes sorry @mugicagonzalez_ we don't allow "Newbies" to use hyperlinks any more due to high numbers of clickbait spammers.
[Helpful hint from community manager - if you just "like" a few posts or mark something as solution or practically anything else, you will gain points and move way beyond Newbie quickly!!]
Scott
Scott
1 - 1 of
11
SOLVED! Thanks to to jczgalla (can't post link to thread)!
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="open_file" compatibility="8.1.003" expanded="true" height="68" name="Open File" width="90" x="45" y="34">
<parameter key="filename" value="/Users/pello/Downloads/TEST_Jette.csv"/>
</operator>
<operator activated="true" class="text:read_document" compatibility="8.1.000" expanded="true" height="68" name="Read Document" width="90" x="179" y="34">
<parameter key="extract_text_only" value="false"/>
</operator>
<operator activated="true" class="text:cut_document" compatibility="8.1.000" expanded="true" height="68" name="Cut Document" width="90" x="313" y="34">
<parameter key="query_type" value="Regular Expression"/>
<list key="string_machting_queries"/>
<list key="regular_expression_queries">
<parameter key="text" value="((?:[^"]+?|"(.|\n)*?"|)*?)\n"/>
</list>
<list key="regular_region_queries"/>
<list key="xpath_queries"/>
<list key="namespaces"/>
<list key="index_queries"/>
<list key="jsonpath_queries"/>
<operator activated="true" class="text:remove_document_parts" compatibility="8.1.000" expanded="true" height="68" name="Remove Document Parts" width="90" x="45" y="34">
<parameter key="deletion_regex" value="""/>
</operator>
<connect from_port="segment" to_op="Remove Document Parts" to_port="document"/>
<connect from_op="Remove Document Parts" from_port="document" to_port="document 1"/>
<portSpacing port="source_segment" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="text:documents_to_data" compatibility="8.1.000" expanded="true" height="82" name="Documents to Data" width="90" x="447" y="34">
<parameter key="text_attribute" value="text"/>
</operator>
<operator activated="true" class="select_attributes" compatibility="8.1.003" expanded="true" height="82" name="Select Attributes" width="90" x="581" y="34">
<parameter key="attribute_filter_type" value="single"/>
<parameter key="attribute" value="text"/>
</operator>
<operator activated="true" class="filter_example_range" compatibility="8.1.003" expanded="true" height="82" name="Filter Example Range" width="90" x="715" y="34">
<parameter key="first_example" value="18"/>
<parameter key="last_example" value="19"/>
</operator>
<operator activated="true" class="split" compatibility="8.1.003" expanded="true" height="82" name="Split" width="90" x="849" y="34">
<parameter key="split_pattern" value=";"/>
</operator>
<operator activated="true" class="rename_by_example_values" compatibility="8.1.003" expanded="true" height="82" name="Rename by Example Values" width="90" x="983" y="34"/>
<connect from_op="Open File" from_port="file" to_op="Read Document" to_port="file"/>
<connect from_op="Read Document" from_port="output" to_op="Cut Document" to_port="document"/>
<connect from_op="Cut Document" from_port="documents" to_op="Documents to Data" to_port="documents 1"/>
<connect from_op="Documents to Data" from_port="example set" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/>
<connect from_op="Filter Example Range" from_port="example set output" to_op="Split" to_port="example set input"/>
<connect from_op="Split" from_port="example set output" to_op="Rename by Example Values" to_port="example set input"/>
<connect from_op="Rename by Example Values" from_port="example set output" to_port="result 1"/>
</process>
</operator>
</process>
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.1.003" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="open_file" compatibility="8.1.003" expanded="true" height="68" name="Open File" width="90" x="45" y="34"> <parameter key="filename" value="/Users/pello/Downloads/TEST_Jette.csv"/> </operator> <operator activated="true" class="text:read_document" compatibility="8.1.000" expanded="true" height="68" name="Read Document" width="90" x="179" y="34"> <parameter key="extract_text_only" value="false"/> </operator> <operator activated="true" class="text:cut_document" compatibility="8.1.000" expanded="true" height="68" name="Cut Document" width="90" x="313" y="34"> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"> <parameter key="text" value="((?:[^"]+?|"(.|\n)*?"|)*?)\n"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> <list key="jsonpath_queries"/> <process expanded="true"> <operator activated="true" class="text:remove_document_parts" compatibility="8.1.000" expanded="true" height="68" name="Remove Document Parts" width="90" x="45" y="34"> <parameter key="deletion_regex" value="""/> </operator> <connect from_port="segment" to_op="Remove Document Parts" to_port="document"/> <connect from_op="Remove Document Parts" from_port="document" to_port="document 1"/> <portSpacing port="source_segment" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:documents_to_data" compatibility="8.1.000" expanded="true" height="82" name="Documents to Data" width="90" x="447" y="34"> <parameter key="text_attribute" value="text"/> </operator> <operator activated="true" class="select_attributes" compatibility="8.1.003" expanded="true" height="82" name="Select Attributes" width="90" x="581" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="text"/> </operator> <operator activated="true" class="filter_example_range" compatibility="8.1.003" expanded="true" height="82" name="Filter Example Range" width="90" x="715" y="34"> <parameter key="first_example" value="18"/> <parameter key="last_example" value="19"/> </operator> <operator activated="true" class="split" compatibility="8.1.003" expanded="true" height="82" name="Split" width="90" x="849" y="34"> <parameter key="split_pattern" value=";"/> </operator> <operator activated="true" class="rename_by_example_values" compatibility="8.1.003" expanded="true" height="82" name="Rename by Example Values" width="90" x="983" y="34"/> <connect from_op="Open File" from_port="file" to_op="Read Document" to_port="file"/> <connect from_op="Read Document" from_port="output" to_op="Cut Document" to_port="document"/> <connect from_op="Cut Document" from_port="documents" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Documents to Data" from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="Rename by Example Values" to_port="example set input"/> <connect from_op="Rename by Example Values" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
