That usually happens when you max out your free API calls. Did you look at your volume of requests you are attempting to have Aylien score vs their limits? If you need to upgrade their paid plans are very reasonable.
Hi,
Could you share the process XML code here to take a closer look at the process and cause for such output?
Cheers,
Pavithra
