🎉Community Raffle - Win $25
Join and Win
how sentiment analysis by python or R
User: "student_compute"
New Altair Community Member
Updated by Jocelyn
Hello
I want to make some tweets by Python or R sentiment Analyze .
I did preprocessing in my rapidminer program.
But I do not know how to use R or python to sentiment Analyze in the program?
Someone knows How? Or is there an example?
Any help is helpful to me.
Thanks in advance
1 - 19 of 191
    User: "kayman"
    I like to use the Vader sentiment part of the NLTK toolkit. It works pretty well with social data (sentiment analysis will always remain a bit of a challenge) and gives a bit more than the usual possitive / negative indications
    Attached sample uses this framework, the example chops the response by sentence and gives the 'vibe' per sentence. I typically use this method to ensure also mixed data get's covered well. But of course you could also use it on the full data.
    What I provided was like this ;
    Review.Body Review.ID Review.Date Review.Title Review.Rating
    Sound is great. Picture is bad XYZ123 Wed Aug 01 10:08:34 CEST 2018 My opinion 3.0
    What it returns is as follows :
    Review.ID sentence compound negative possitive neutral Review.Date Review.Title Review.Rating
    XYZ123 Sound is great. 0.6249 0.0 0.672 0.328 Wed Aug 01 10:08:34 CEST 2018 My opinion 3.0
    XYZ123 Picture is bad -0.5423 0.636 0.0 0.364 Wed Aug 01 10:08:34 CEST 2018 My opinion 3.0
    The more negative or possitive the compound value (range -1 to +1), the more likely it will be that the sentiment of a given sentence is equally negative or possitive
    <?xml version="1.0" encoding="UTF-8"?><process version="8.2.000">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.2.000" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="generate_data_user_specification" compatibility="8.2.000" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="112" y="85">
    <list key="attribute_values">
    <parameter key="Review.Body" value="&quot;Sound is great. Picture is bad&quot;"/>
    <parameter key="Review.ID" value="&quot;XYZ123&quot;"/>
    <parameter key="Review.Date" value="date_now()"/>
    <parameter key="Review.Title" value="&quot;My opinion&quot;"/>
    <parameter key="Review.Rating" value="3"/>
    </list>
    <list key="set_additional_roles"/>
    </operator>
    <operator activated="true" class="filter_example_range" compatibility="8.2.000" expanded="true" height="82" name="Filter Example Range" width="90" x="179" y="289">
    <parameter key="first_example" value="1"/>
    <parameter key="last_example" value="5"/>
    </operator>
    <operator activated="true" class="subprocess" compatibility="8.2.000" expanded="true" height="103" name="Subprocess" width="90" x="313" y="289">
    <operator activated="true" class="set_role" compatibility="8.2.000" expanded="true" height="82" name="Set Role" width="90" x="246" y="34">
    <parameter key="attribute_name" value="Review.ID"/>
    <parameter key="target_role" value="id"/>
    <description align="center" color="transparent" colored="false" width="126">define review as id</description>
    </operator>
    <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="514" y="187">
    <parameter key="attribute_filter_type" value="subset"/>
    <parameter key="attribute" value="review-body"/>
    <parameter key="attributes" value="|Review.Body"/>
    <description align="center" color="transparent" colored="false" width="126">Keep only the ones we need&lt;br&gt;&lt;br&gt;We focus only on body but we could also concatenate with the title</description>
    </operator>
    <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes (3)" width="90" x="916" y="289">
    <parameter key="attribute_filter_type" value="single"/>
    <parameter key="attribute" value="Review.Body"/>
    <parameter key="invert_selection" value="true"/>
    <description align="center" color="transparent" colored="false" width="126">Get all other fields</description>
    </operator>
    <operator activated="true" class="replace" compatibility="8.2.000" expanded="true" height="82" name="Replace (3)" width="90" x="916" y="34">
    <parameter key="replace_what" value="\n"/>
    <parameter key="replace_by" value=" "/>
    <description align="center" color="transparent" colored="false" width="126">replace linebreaks as python doesn't like these too much</description>
    </operator>
    <connect from_port="in 1" to_op="Set Role" to_port="example set input"/>
    <connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
    <connect from_op="Select Attributes" from_port="example set output" to_op="Replace (3)" to_port="example set input"/>
    <connect from_op="Select Attributes" from_port="original" to_op="Select Attributes (3)" to_port="example set input"/>
    <connect from_op="Select Attributes (3)" from_port="example set output" to_port="out 2"/>
    <connect from_op="Replace (3)" from_port="example set output" to_port="out 1"/>
    <portSpacing port="source_in 1" spacing="0"/>
    <portSpacing port="source_in 2" spacing="0"/>
    <portSpacing port="sink_out 1" spacing="0"/>
    <portSpacing port="sink_out 2" spacing="0"/>
    <portSpacing port="sink_out 3" spacing="0"/>
    </process>
    <description align="center" color="transparent" colored="false" width="126">Normalization and preparation</description>
    </operator>
    <operator activated="true" class="python_scripting:execute_python" compatibility="7.4.000" expanded="true" height="82" name="Execute Python" width="90" x="447" y="34">
    <parameter key="script" value="import pandas&#10;from nltk.sentiment.vader import SentimentIntensityAnalyzer&#10;from nltk import tokenize&#10;&#10;def rm_main(data):&#10;&#10; sent_all=[]&#10; score_all=[]&#10; id_all=[]&#10; &#10; data_split = pandas.DataFrame()&#10; for index,row in data.iterrows():&#10; review=row[&quot;Review.Body&quot;]&#10; _id=row[&quot;Review.ID&quot;]&#10; &#10; lines_list = tokenize.sent_tokenize(review)&#10; sid = SentimentIntensityAnalyzer()&#10; for sentence in lines_list:&#10;&#10; ss = sid.polarity_scores(sentence)&#10; id_all.append(_id)&#10; sent_all.append(sentence)&#10; score_all.append(ss)&#10; &#10; data_split['Review.ID']=id_all&#10; data_split['sentence']=sent_all&#10; data_split['scores']=score_all&#10;&#10; #print(data)&#10; &#10; return data_split"/>
    <description align="center" color="transparent" colored="false" width="126">We use nltk / vader framework to do sentiment analysis.&lt;br&gt;&lt;br&gt;Can be easily replaced with other frameworks or custom code</description>
    </operator>
    <operator activated="true" class="subprocess" compatibility="8.2.000" expanded="true" height="103" name="Subprocess (2)" width="90" x="581" y="289">
    <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes" width="90" x="246" y="34">
    <list key="function_descriptions">
    <parameter key="compound" value="parse(replaceAll([scores],&quot;^.*?'compound': (-?\\d+.\\d+).*$&quot;,&quot;$1&quot;))"/>
    <parameter key="negative" value="parse(replaceAll([scores],&quot;^.*?'neg': (-?\\d+.\\d+).*$&quot;,&quot;$1&quot;))"/>
    <parameter key="possitive" value="parse(replaceAll([scores],&quot;^.*?'pos': (-?\\d+.\\d+).*$&quot;,&quot;$1&quot;))"/>
    <parameter key="neutral" value="parse(replaceAll([scores],&quot;^.*?'neu': (-?\\d+.\\d+).*$&quot;,&quot;$1&quot;))"/>
    </list>
    </operator>
    <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes (2)" width="90" x="380" y="34">
    <parameter key="attribute" value="scores"/>
    </operator>
    <operator activated="true" class="set_role" compatibility="8.2.000" expanded="true" height="82" name="Set Role (2)" width="90" x="514" y="34">
    </operator>
    <operator activated="true" class="concurrency:join" compatibility="8.2.000" expanded="true" height="82" name="Join (2)" width="90" x="514" y="187">
    <list key="key_attributes"/>
    </operator>
    <connect from_port="in 1" to_op="Generate Attributes" to_port="example set input"/>
    <connect from_port="in 2" to_op="Join (2)" to_port="right"/>
    <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/>
    <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/>
    <connect from_op="Set Role (2)" from_port="example set output" to_op="Join (2)" to_port="left"/>
    <connect from_op="Join (2)" from_port="join" to_port="out 1"/>
    <portSpacing port="source_in 3" spacing="0"/>
    </process>
    <description align="center" color="transparent" colored="false" width="126">post processing</description>
    </operator>
    <connect from_op="Generate Data by User Specification" from_port="output" to_op="Filter Example Range" to_port="example set input"/>
    <connect from_op="Filter Example Range" from_port="original" to_op="Subprocess" to_port="in 1"/>
    <connect from_op="Subprocess" from_port="out 1" to_op="Execute Python" to_port="input 1"/>
    <connect from_op="Subprocess" from_port="out 2" to_op="Subprocess (2)" to_port="in 2"/>
    <connect from_op="Execute Python" from_port="output 1" to_op="Subprocess (2)" to_port="in 1"/>
    <connect from_op="Subprocess (2)" from_port="out 1" to_port="result 1"/>
    <description align="center" color="yellow" colored="false" height="108" resized="true" width="736" x="102" y="497">http://www.nltk.org/_modules/nltk/sentiment/vader.html&lt;br&gt;&lt;br&gt;http://t-redactyl.io/blog/2017/04/using-vader-to-handle-sentiment-analysis-with-social-media-text.html</description&gt;
    </process>
    </operator>
    </process>
    User: "lionelderkrikor"
    Hi @student_compute,
    In addition to the solution of @kayman, I propose a Python script using the "textblob" library.
    From your text attribute, this script delivers a polarity between -1 and +1 where :
    -1 (negative) < polarity < +1 (positive).
    To execute this script, you have to set the name of your text attribute (with quotes) in the Set Macros operator :
    The process :
    <?xml version="1.0" encoding="UTF-8"?><process version="9.0.000-BETA4">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="9.0.000-BETA4" expanded="true" name="Process">
    <operator activated="true" class="social_media:search_twitter" compatibility="9.0.000-BETA" expanded="true" height="68" name="Search Twitter" width="90" x="112" y="85">
    <parameter key="connection" value="dkk"/>
    <parameter key="query" value="iphone"/>
    <parameter key="limit" value="20"/>
    <parameter key="language" value="en"/>
    </operator>
    <operator activated="true" class="set_macros" compatibility="9.0.000-BETA4" expanded="true" height="82" name="Set Macros" width="90" x="246" y="85">
    <list key="macros">
    <parameter key="textAttribute" value="'Text'"/>
    </list>
    </operator>
    <operator activated="true" class="python_scripting:execute_python" compatibility="7.4.000" expanded="true" height="82" name="Execute Python" width="90" x="380" y="85">
    <parameter key="script" value="import pandas&#10;from textblob import TextBlob&#10;&#10;textAtt = %{textAttribute}&#10;&#10;# rm_main is a mandatory function, &#10;# the number of arguments has to be the number of input ports (can be none)&#10;def sent(text) : &#10;&#10; testimonial = TextBlob(str(text))&#10; sentiment = testimonial.sentiment.polarity &#10; return sentiment&#10;&#10;&#10;def rm_main(data):&#10; &#10; data['polarity'] =data[textAtt].apply(sent)&#10; return data "/>
    </operator>
    <connect from_op="Search Twitter" from_port="output" to_op="Set Macros" to_port="through 1"/>
    <connect from_op="Set Macros" from_port="through 1" to_op="Execute Python" to_port="input 1"/>
    <connect from_op="Execute Python" from_port="output 1" to_port="result 1"/>
    </process>
    </operator>
    </process>
    Regards,
    Lionel
    OP
    Hi, thank you very much
    How to get on points, in a new column. Insert a positive word and a negative word in front of each sentence?
    Thanks a lot
    I think you can use Generate Attributes and Set Data operators and eventually if needed Reorder Attributes operator.
    Regards,
    Lionel
    OP
    Hello
    Thank you so much
    I used
    But I do not know how to show the polarity of sentences based on scores
    look
    Could this be the case?
    Thanks
    You can, indeed, create a new attribute "Pol" defined by (for example) :
     - if -1 < polarity < -0,1, then Pol = "negative"
     - if -0,1 <= polarity <= 0,1, then Pol = "neutral"
     - if 0,1 < polarity < 1, then Pol = "positive"
    Note : You can, of, course, choose and set other thresholds than -0,1 / 0,1.
    Here the associated process :
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    </operator>
    <list key="macros">
    </list>
    </operator>
    </operator>
    <operator activated="true" class="generate_attributes" compatibility="9.0.000-BETA4" expanded="true" height="82" name="Generate Attributes" width="90" x="514" y="85">
    <parameter key="Pol" value="if(polarity&lt;-0.1,&quot;negative&quot;,if(polarity&gt;0.1,&quot;positive&quot;,&quot;neutral&quot;))"/>
    </list>
    </operator>
    <connect from_op="Execute Python" from_port="output 1" to_op="Generate Attributes" to_port="example set input"/>
    <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
    </process>
    </operator>
    </process>
    Regards,
    Lionel
    OP
    Thank you so much
    How to download rapidminer version 9?
    Thanks
    OP
    Hello
    Thank you so much
    Is there a perpelexity parameter in the new version for LDA? Or more facilities?
    OP
    Hellokeyman
    I've used your code. But he did not know the package NLTK
    How do I download this package and introduce RapidMiner
    I use Anacanda. I installed the textblob package but I can not package it
    May I help how to do to install?
    Thank you
    Yes, there is Perplexity as one of performance measure in the last version of LDA.
    Regards,
    Lionel
    OP
    lionelderkrikor dear
    Thank you:heart:
    Hellokeyman
    Thank you
    OP
    Hello
    How to install nltk package and use it? The program has an error that this package does not exist !! Thankful
    And
    I downloaded and run RapidMiner 9. But I do not know how to find Perplexity mesure for assessing LDA? Does anyone know?
    Thank
    "How to install nltk package and use it?"
    Lauch the windows "invite de commande" (type "cmd" in the search bar of Windows 10) and type de following command : pip install nltk
    "But I do not know how to find Perplexity mesure for assessing LDA"
    Connect the per output port of LDA operator to the res port
    Regards,
    Lionel
    OP
    Hello
    Thank you
    Thank you
    Excuse me about perpelexity in the LDA may I send a sample shot screenshot?
    Thankful
    Hi,
    Here the screenshots relativ to LDA :
    Regards,
    Lionel
    OP
    Hello
    Thank you so much
    Just might say
    What other things do they use?
    I mean avgs ???
    OP
    Hello Sorry, I raised the topic again I tried a lot. Do nltk I installed it. But there is an error in the run. Which I myself could not solve. Can anyone help me? And about The amounts of AVGs reported on the LDA output can be explained to me. What is their use? Thanks for all your help
    Can you share your process in order we can reproduce your bug ?
    Try to add in the Python script after the others nltk.download('xxxxxx') :
    nltk.download('vader_lexicon')
    and execute the process one time.
    Regards,
    Lionel
