Altair RISE
Nominate Yourself Now!
Error
User: "skakkana1"
New Altair Community Member
Updated by Jocelyn
I am getting an unknown attribute error whilw I tried running after adding SMOTE upsampling.
1 - 6 of 61
    User: "lionelderkrikor"
    Hi @skakkana1,
    Can you share your process and your dataset in order we can reproduce what you observe ?
    Regards,
    Lionel
    User: "skakkana1"
    OP
    User: "tftemme"
    Hi @skakkana1,
    Sorry for answering so late. I overlooked your original thread. But we got reports of a similar error and found a bug which is fixed with version 1.5.0 of the Operator Toolbox, released today (2018-09-14)-.
    The problem was that the operator failed when the label attribute contained comparison characters (e.g. =, <, ...). Hopefully this was also the case for your setup and it should be fixed now. If not, feel free to post your problem again, best with the process xml and a sample data set attached.
    Best regards,
    Fabian
    User: "apoorva1"
    having same error in my case still..please help
    Hi @apoorva1,
    did you update toolbox?
    BR,
    Martin
    User: "Widyangga"
    Hi @skakkana1,
    I found that if you want to use SMOTE Upsampling Operator, you should change your attribute name which become label/class to "class".
    I see your attribute which become label is Fraud Flag, so change the name attribute become "class".
    I have same problem and then I change the name attribute, it's work.
