🎉Community Raffle - Win $25
Join and Win
Relationship between the attributes consists of nominal, polynominal and numerical data
User: "azziaty256"
New Altair Community Member
Updated by Jocelyn
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.2.001" expanded="true" height="68" name="Retrieve 8 Data Cleaning test 3" width="90" x="112" y="34">
<parameter key="repository_entry" value="8 Data Cleaning test 3"/>
</operator>
<operator activated="true" class="concurrency:correlation_matrix" compatibility="8.2.000" expanded="true" height="103" name="Correlation Matrix" width="90" x="447" y="238">
<parameter key="include_special_attributes" value="true"/>
</operator>
<connect from_op="Retrieve 8 Data Cleaning test 3" from_port="output" to_op="Correlation Matrix" to_port="example set"/>
<connect from_op="Correlation Matrix" from_port="example set" to_port="result 2"/>
<connect from_op="Correlation Matrix" from_port="matrix" to_port="result 1"/>
<portSpacing port="sink_result 1" spacing="63"/>
<portSpacing port="sink_result 2" spacing="21"/>
<portSpacing port="sink_result 3" spacing="147"/>
</process>
</operator>
</process>
1 - 4 of 41
    User: "azziaty256"
    OP
    Sorry I am newbie..
    Please help me how to make correlation between the attributes for a nominal, polynominal and numerical data types.
    User: "sgenzer"
    Altair Employee
    Accepted Answer
    hello @azziaty256 - welcome to the community! Yes you can only use Correlation Matrix with numerical attributes as it is simply calculating pairwise r (or r^2 if you choose) correlation coefficients. It would be rather odd to calculate r (or r^2) between nominal / polynominal attributes as they are not numerical. I would recommend rethinking exactly what you are trying to do.
    Scott
    User: "IngoRM"
    Accepted Answer
    Hi,
    In RapidMiner's Auto Model, there is some smart preprocessing done so that the correlations can also be calculated for your non-numerical attributes / columns.  I would suggest to give it a try and see if this is what you are after.  If yes, you can open the correlation process from Auto Model and adapt it to your needs.
    Best,
    Ingo
    User: "azziaty256"
    OP
    Thank you..ok i got it👍
