<?xml version="1.0" encoding="UTF-8"?><process version="8.2.001">
 <context>
 <input/>
 <output/>
 <macros/>
 </context>
 <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
 <process expanded="true">
 <operator activated="true" class="retrieve" compatibility="8.2.001" expanded="true" height="68" name="Retrieve 8 Data Cleaning test 3" width="90" x="112" y="34">
 <parameter key="repository_entry" value="8 Data Cleaning test 3"/>
 <operator activated="true" class="concurrency:correlation_matrix" compatibility="8.2.000" expanded="true" height="103" name="Correlation Matrix" width="90" x="447" y="238">
 <connect from_op="Retrieve 8 Data Cleaning test 3" from_port="output" to_op="Correlation Matrix" to_port="example set"/>
 <connect from_op="Correlation Matrix" from_port="example set" to_port="result 2"/>
 <connect from_op="Correlation Matrix" from_port="matrix" to_port="result 1"/>
 <portSpacing port="sink_result 1" spacing="63"/>
 <portSpacing port="sink_result 2" spacing="21"/>
 <portSpacing port="sink_result 3" spacing="147"/>
 </process>
</process>
