🎉Community Raffle - Win $25
Join and Win
Twitter Textmining User Count
a_trunkUser: "a_trunk"
New Altair Community Member
Updated by Jocelyn
Hello, i am a Newbie and work with rapid miner for education. No i have a question where i need help:
I have to textmining twitter by a special keyword. It works easy. But now i want to select only the user, which post more than 3 tweets in the selection. So how i have to build in a querry <3 or similar? And how can i sort them in the result from most tweets to only one tweet?
I try some different solution but i did not find a answer...
Best regards and many thanks
1 - 3 of 31
    kypexinUser: "kypexin"
    Accepted Answer
    Hi @a_trunk
    The easiest way to do it is to use aggregation.
    For example, let's assume you have a very simple dataset format, "USER | TWEET" (one column is username and second a tweet text).
    So, you can use Aggregate operator then, in parameters choose 'group by attributes' = 'user' and 'aggregation attributes' = 'count(tweet)'.
    This way you will get a list of users each with a total number of their tweets.
    OP
    Yes perfect! Works... Many thanks :-)
    OP
    Hello,
    i have one question / problem more: I count the quantities of tweets from an user, but how can i build a sum of the quantities of the tweets and a retweets? I will analyse a user which made the most tweets and also the quantities of the retweets of the users post?
    Thanks for help.
    Armin
